Customization Options for TCH
I've already posted this inside another thread, but I think that interest is likely great enough to warrant having a separate thread, where this information can be found more easily. So, from the TCH Repair Manual, here are the pages listing (I believe) all the available customization options, most of which require to be changed by the dealer.
Stan
Stan
No, you have to take it to the dealer to have any of this changed.
Thanks, SPL!
If I'm reading it correctly, we can open/close the sunroof using the remote. I had no idea, and I'd missed that feature it since moving to the TCH from the Passat. As soon as it stops raining I'll check it out
![Smile](https://electricvehicleforums.com/forums/images/smilies/emotikons/smile.gif)
turk — Since I don't have a sunroof, I'll leave it to you to check this out!
abward — The dealer uses a Toyota proprietary tool called the Intelligent Tester to make the customization changes. So, I think you'll have to let them do it. Sorry!
Stan
Stan
Take a look:
(a) Driver and front passenger side seat belt buzzers
(1) Turn the ignition switch to the ON position.
(2) Press the ODO/TRIP switch until the odometer displays "ODO".
(3) Turn the ignition switch off.
(4) Turn the ignition switch to the ON position.
(5) Press the ODO/TRIP switch immediately (within 6 seconds) and hold it down for 10 seconds or more.
(6) Continue holding down the ODO/TRIP switch and fasten the driver side seat belt.
(7) Check that the odometer displays either "b-on" or "b-oFF".
(8) Press the ODO/TRIP switch to change the display to "b-oFF".
(9) Turn the ignition switch off.
(10)Turn the ignition switch to the ON position.
(11)Check that no buzzer sounds.
(b) Front passenger side seat belt buzzer(2) Press the ODO/TRIP switch until the odometer displays "ODO".
(5) Sit in the front passenger seat. Press the ODO/TRIP switch immediately (within 6 seconds) and hold it down for 10 seconds or more.
(6) Sit in the front passenger seat. Continue holding down the ODO/TRIP switch and fasten the front passenger side seat belt.
Take a look:
(b) Front passenger side seat belt buzzer(1) Turn the ignition switch to the ON position.
Where did you find this gem ? finally it is the end of the D&?% buzzer !
thanks
