Couple Questions I can't find in Manual
1) What does the B on my gear shifter do? Does it engage any more stuff or is it just the old 'L' and Toyota uses a different word for it?
2) After much looking, I don't see your old tried & true 'car battery'. The thing that wears out after 24 - 36 months and usually catches you the first really cold morning by not starting your car. Having no traditional starter I was wondering if it even had one, but then the Highlander Hybrid we got my wife does, so I am confused.
Re: Couple Questions I can't find in Manual
The 'car battery' is located in the trunk. If you look in the trunk on the right side you will notice a black plastic cover. If you open that you will see the battery. It's not your traditional battery as you see in other cars. I'm sure others will chime in with more specifics on that battery. There is a lot of information about it but you'll have to use the search function.
Hope this helps.
For one thing, the battery doesn't have to crank the engine, so it may have lower cold cranking power. Also it is a sealed type and regular battery could actually be dangerous, since it could vent hydrogen inside closed trunk, which holds NIMH packs and some relays. Good news is the battery should last longer than normal and even when weak, the car should start as usual. The bad news is Toyota charges a lot of money for it and OEM replacement would have to have very similar charging characteristics, otherwise the new battery wouldn't last long being constantly over or under charged. Either way we still have few years before we need to worry about it.
That 12-volt battery is an "absorptive glass mat" type of sealed lead-acid battery. Its rated capacity is only 48 Ah (it powers only the electronics — it never has to crank the ICE). This type of lead-acid battery is chosen because it can take repeated deep discharges without damage (unlike regular lead-acid batteries), but it must be charged and discharged carefully at a controlled rate dependent on battery temperature, amongst other things. It has an internal temperature sensor (you'll see the connector near the + terminal), and an over-pressure venting pipe that runs to the outside of the car (also near the + terminal). It is custom made for Toyota, and should only be replaced by the same model.
Stan
Stan
When the TCH 12 volt battery finally dies, I will most likely replace it with an Optima deep cycle battery. They are AGM construction and the over pressure vent accepts remote venting tubing. At $130, it is a lot less than the Toyota dealer for essentially the same battery.
It still might not be a "regular" (starting) battery. My guess is that it is a flooded (liquid electrolyte) deep-cycle battery.
I think you guys missed hiswhole question. He can't find the battery that resemebles a regular one. ITS IN THE TRUNK ON THE RIGHT BEHIND A PANEL. Although the info you guys are giving is helpful to know I think he just wanted to know where it was. But I have been wrong before so please excuse me if I am.
That pretty much covered it. Didn't it?
MountainsAreNoImpedence
08-18-2012 04:45 PM
SilentAltima
10
08-17-2007 12:24 AM
BrendanMT
Toyota Highlander Hybrid
08-26-2006 06:12 PM
tgreb
08-18-2006 07:32 AM
