Coolant Leak?
I found a puddle of a clear watery substance underneath the engine block area this morning. I checked the coolant reservoirs and the converter/inverter reservoir was near the low marker. I made an appointment to take the car in this Friday.
I found that in a consumer report said that the 04-06 Prius may develop coolant leak in the converter/inverter assembly. Has anyone else had this issue before?
I think you guys are right. I went home and jacked the car up and found the drip line from I'm guessing the AC. I didn't know there was a drip line.
I haven't been using the AC since it's been fall type weather here in Utah. I find that unusual for there to be water dripping from the drip line. Is there condensation buildup from just using the blower?
Thanks for the replies.
Anywho yes it is normal for most cars to drip water from the a/c so if you ever see what you descriped as the leak color clear water like looking or oil even if its not thick than its not oil if you see it fresh and there is a color other than brown/black or it is one of three things water,washer fluid, coolant
washer fluid will be color and very runny you should know what yours looks like
coolant-green or pink very watery not very full bodied if you know wine talk i guess.
oil-thick black or brown
i believe i have probably repeated myself and will stop i hope this helps someone
