Camry transaxle sketch or diagram?
Old Aug 18, 2006 | 11:29 AM
bwilson4web's Avatar
Engineering first
Question Camry transaxle sketch or diagram?
Hi,
I haven't seen a sketch or diagram for the Camry transaxle. I know how our Prius transaxle work and figured the Camry was the same. But someone (not a Prius owner) thinks there is an extra planetary gear in the Camry transaxle and just don't know.
Has anyone seen a paper, maintenance guide or other sketch that shows the parts of a Camry transaxle?
Thanks,
Bob Wilson
Old Aug 19, 2006 | 09:31 AM
ken1784's Avatar
Default Re: Camry transaxle sketch or diagram?
Hi Bob,
The Camry Hybrid has the reduction gear same as Highlander and RX400h.
http://www.toyota.co.jp/en/tech/environment/powertrain/hybrid/index.htm
Ken@Japan
Old Aug 19, 2006 | 10:11 AM
schmidtj's Avatar
Keeping Toyota Solvent
Originally Posted by bwilson4web
Hi,
Thanks,
Bob Wilson
See attached. Page 2 specfically.
J
File Type: pdf
Old Aug 19, 2006 | 10:19 AM
mayall's Avatar
Yes, there are 2 electric motor/generators and 2 planetary gear sets.
Will Mayall
Old Aug 19, 2006 | 10:34 AM
Engineering first
Thumbs up Re: Camry transaxle sketch or diagram?
Will Mayall
Thanks to all who replied! (What a great place, GreenHybrid.com!)
The motor speed reduction gear makes a lot of sense and it appears to be a fixed ratio reduction unit. I can see where it extends the range MG2 can contribute motive force. I've added the "Toyota.pdf" file to my records folder.
It would be misleading to suggest that this fixed ratio, planetary gear has any 'shifting' capability. It is basicly extending the low-end range of the MG2 over a wider speed range. Excellent!
Bob Wilson
Old Aug 19, 2006 | 08:43 PM
nash's Avatar
Very interesting - I did not know a compound gearing was used on the TCH. A tech at the dealer said the TCH uses an isolated cooling circuit for the HSD, independent from the ICE cooling. I am most curious if anyone has any info on the cooling of the TCH. Is the temperature of the HSD lower than the ICE? Heat buildup in the Prius HSD is a limitation and possibly a contributor to the early breakdown of the HSD oil. A few folks have had oil analysis done on the Prius HSD oil at 60K miles, and it showed significant breakdown and loss of viscosity.
Old Aug 19, 2006 | 11:08 PM
schmidtj's Avatar
The second cooling system is for the DC-DC Inverter. An electronic component that potentially can develope a LOT of heat.
J
Old Aug 19, 2006 | 11:26 PM
ken1784's Avatar
Also note that GS450h and LS600h have two speed (3.9:1 - 1.9:1) variable reduction gearset.
http://priuschat.com/index.php?showtopic=20684&st=10
Ken@Japan
Old Aug 20, 2006 | 01:16 AM
Engineering first
Hi,
I can not answer about the TCH system but only the Prius I appears to have the problem. The current model, Prius II, does not have this problem after Toyota added some ball bearings and started using a lower viscosity transmission oil. No doubt the TCH benefits from this 'lessons learned.'
Bob Wilson
GeorgiaHybrid
Oct 1, 2025 04:40 PM
RayP
Aug 17, 2013 05:16 AM
todd911
Oct 6, 2009 02:04 PM
buyhevs
May 15, 2009 11:44 AM
raypou
Jun 23, 2005 09:00 PM
