A/C system generate H2O puddles
Old Aug 26, 2006 | 06:08 PM
Fredoulis's Avatar
Default A/C system generate H2O puddles
We've been pretty hot here in Los Angeles and have I noticed two puddles of clear liquid (seems like water - clear, low viscosity) after a nice hot drive with the A/C system on.
A small puddle forms from under the front engine compartment and a rather larger puddle (almost 12 inches round) almost directly below the HV battery in the trunk.
Seems like a lot of condensed water for a low humidity region? What's been your experience?
Old Aug 26, 2006 | 06:39 PM
flopshot's Avatar
Default Re: A/C system generate H2O puddles
I live in Gilroy, which is drier than LA. I get "large" condensation puddles after I use the A/C. That's just the way the TCH condensor works (my CaddySTS used to do the same), I wouldn't worry about it unless you find yourself having A/C problems.
Old Aug 26, 2006 | 06:41 PM
stevenvillatoro's Avatar
Arrow Re: A/C system generate H2O puddles
Few people know this, but the real reason it's called a hybrid is that you can get water from either end. It's normal!
cmobile
Mar 16, 2012 04:49 PM
Ed_of_Indy
Apr 24, 2011 07:26 AM
Guss
Aug 7, 2009 01:09 PM
Paulgw
Nov 22, 2006 06:31 AM
