Best replacement cabin air filter
Old Aug 3, 2009 | 07:09 PM
seaford's Avatar
Default Best replacement cabin air filter
Bosch replacement filter??, Puralators?? or any other recommendations?? Going to change it ourselves... thanks..
Old Aug 3, 2009 | 09:49 PM
alphabetbackward's Avatar
Default Re: Best replacement cabin air filter
I bought a couple Purolator C35667 from PepBoys for ~12 bucks a piece which is much less than the 27 that the dealer wanted. They looked really similar (if not identical) when I replaced them.
Old Aug 3, 2009 | 11:45 PM
rburt07's Avatar
I was quoted for $29 for the dealer's cabin air filter. I ended up buying a Wix for about $15 locally. I heard years ago that Purolator makes the Toyota oem filters to Toyota's specs. I would love to buy Purolator but it's 80 miles to our nearest PepBoys in El Paso.
Old Aug 4, 2009 | 12:49 AM
haroldo's Avatar
best? how does one measure indoor air quality.
to me best is cheapest
Old Aug 4, 2009 | 08:18 AM
I also read on another forum that some guy uses AC air filters for his house. He simply cuts them to size which is even cheaper.
Old Aug 4, 2009 | 11:44 AM
Intrus's Avatar
Professional Hacker
I get mine from Napa autoparts. They are about $8
Old Oct 14, 2010 | 08:11 PM
bugs's Avatar
700 Mi Camry Club Member
I like the build on the Fram FreshBreeze CF10139 (Green box) for my Camry 2007 Hybrid. The filter fits fine and Walmart has them on clearance for 13 dollars. This is not the cheap flimpsy filters. They are rock solid with charcoal activated feature as well as baking soda added in for that clean fresh smell. Found the cabin filters in the auto department in the clearance section.
Sorry have not posted in awhile. Nothing wrong with the Camry yet. Knock on wood.
Old Oct 15, 2010 | 01:12 AM
haroldo's Avatar
Why post the same item in four separate threads, some well over a year old?
I like cabin air filters as much as the next guy, but this is one of the most unimportant parts of the car.
One of your passengers can "let one fly" and all the filtration in the world won't protect you. Nor will it prevent the car from getting skunked.
I buy the filters online for under ten bucks (looking for the cheapest) and don't think in terms of the rigidity nor quality. They all filter out some stuff, but it's not NASA nor clean room quality filtration where talking about here. The cheap ones online are pretty rigid, too
Old Oct 15, 2010 | 10:11 AM
bugs's Avatar
Hi Harold
I posted a few times because I figured someone
might be looking for a cabin filter for a good
value. I understand you may not feel that a camry
might not need a higher end cabin filter. I respect
your thoughts. However, for the folks that do want
a better filter in terms of quality material and activated
charcoal, I just wanted to let them know of a
clearance I found.
As for me, I prefer a better made cabin filter. I Ebay
for my needs too. Thanks for your comments. Have a
good day.
dgyimao
Dec 31, 2009 09:38 AM
sanosteam
Dec 26, 2009 07:17 AM
bar10dah
Oct 18, 2009 07:04 PM
bugs
May 26, 2009 12:05 AM
