Annoying Alert Message
Old Oct 26, 2006 | 03:04 PM
Lilarienne's Avatar
Default Annoying Alert Message
LOW WASHER FLUID! This message is so urgent that it has to display continuously and reappear almost instantly upon being "dismissed" by pressing the display button. Yes, I know I need washer fluid, thanks, but I would like to see my usual display while I am on the way to buy the darn washer fluid.
Old Oct 26, 2006 | 04:25 PM
FL07THC's Avatar
Default Re: Annoying Alert Message
Its funny. Mine just started this the other day and I was going to post about this. An alert when starting the car would be nice, however I dont need to be alerted 3 times on the way to work. ITS NOT THAT **** IMPORTANT!!
Old Oct 26, 2006 | 05:46 PM
charlesc's Avatar
I'm at about 4500 miles and my display keeps reminding me "maint req soon"! I'm hoping to get into the dealer this weekend the first oil change. Sure do hope they have 0w-20 synthetic!
Old Oct 27, 2006 | 04:29 AM
Samuelrd1's Avatar
Had this on my VW. As the fluid sloshed around in the container, the warming would keep coming back, (Fast curves, quick stops etc.) Just got used to topping it off more frequently.
Old Oct 27, 2006 | 09:19 AM
GreenHawaii's Avatar
Try to change it before it hits 5,000 or else you'll be really annoyed - I went over 5,000 waiting for my service appointment and the darn Maintenance Required display stays on all the time! When you change the display screens, you see the screen you are trying to view for a few seconds then it goes right back to "Maintenance Required."
Old Oct 27, 2006 | 09:24 AM
FL07THC's Avatar
So it comes on at 4500 miles? I am 100 away from that.
Old Oct 27, 2006 | 09:34 AM
Orcrone's Avatar
At 4500 miles it will come on and say something like "maintenance reqd" on the MFD, along with lighting a red triangle with an asterisk on the dash for a few seconds after startup. After that it's normal. However, once you hit 5000 miles it's as GreenHawaii points out with the display staying in that mode, giving you the other functions for a few seconds if you press the DISP button on the steering wheel.
You can reset it yourself, but it starts the internal 5000 mile countdown from when it's reset. So you'll be starting it early, but eliminating the hassle. I don't know if resetting it upon leaving the dealership will cause the 5000 mile countdown to reset.
Old Nov 22, 2006 | 04:39 PM
belbe's Avatar
Boy, I should say it is annoying! I just hit bottom and it is constantly on. At least there is no annoying DING or BUZZ to go with it! It's raining right now but hopefully tomorrow when it is daytime and dry I can fill that hungry little puppy and have it quit flashing at me!
Thanks for the warning about the maintainence lights...why do I have in my head that I should have my oil changed at 3200 miles? I bought the lifetime free oil changes (4x per year) so perhaps that is where it is coming from?
Barb
Old Jun 18, 2007 | 09:41 AM
rjkbj's Avatar
I am having the same issue. Maint Reqd is on all the time. I changed oil at 4500. Now I'm at 5800 and I cant get it to turn off.
no one has said HOW to reset it. Does anyone know?
Old Jun 18, 2007 | 10:40 AM
mikieboyblue's Avatar
Pull the fuse to the ECU or disconnect the 12v battery? Go to the dealer and have them clear the code? Not sure how it works. I'm at only 3200 miles.
