Advise requested, "Low Engine Oil Pressure" MIL
Old Aug 18, 2011 | 07:12 AM
schmidtj's Avatar
Keeping Toyota Solvent
Default Advise requested, "Low Engine Oil Pressure" MIL
Hello,
2007 Camry Hybrid.
I received a Master Indicator Light (MIL) (Red Triangle with Exclamation) and the message "Low Engine Oil Pressure".
I drove into a parking lot and while locating a parking spot the error cleared (no Triangle, no text message).
I brought it to the dealer 30 minutes later and they said "No Codes in the computer error log". They don't know what the problem was if any.
So I need some advise.
Do I have an oil pressure problem? If yes, why was it not logged?
Do I have a computer problem of some sort that raised a nonexistant error warning? Since there really was not error there was nothing to log?
Sun spots?
I thought maybe a scan guage might track the oil pressure but on second thought the oil pressure of zero is perfectly normal for a hybrid as long as the engine is not running.
Any thoughts/advise appreciated.
J
Old Aug 18, 2011 | 09:03 AM
lincolnshibuya's Avatar
Default Re: Advise requested, "Low Engine Oil Pressure" MIL
check your oil level, if it's low then it will cause that MIL, otherwise it's just a fluke on the computer.
Old Aug 18, 2011 | 11:04 AM
schmidtj's Avatar
Oil level is fine. It was the first thing they checked.
So does the fact that a MIL was raised without a matching code being written mean something is wrong with the system?
J
Old Aug 18, 2011 | 04:28 PM
SteveHansen's Avatar
Pragmatist
An oil-pressure reading out-of-spec means one of two things. Either the oil pressure is low, or the oil pressure sensor is having an electrical problem. Either can be transient.
I would get a fresh oil change, and wiggle the wire on the oil-pressure sensor. Many electrical problems are caused by corrosion in the connections. Wiggling the connection abrades the corrosion.
I do not know why a code would be displayed the operator without also being recorded. That does seem strange.
Old Aug 18, 2011 | 04:46 PM
schmidtj's Avatar
Thank you.
Can someone give me a hint as to where the oil pressure sensor is located?
2007 Camry Hybrid
J
Old Aug 18, 2011 | 10:05 PM
check this out
http://www.facebook.com/photo.php?fb...type=1&theater
ask your dealer if they did a pressure check or you can do it yourself. yep an oil and filter change will at least relieve you of worries.
Old Aug 21, 2011 | 04:20 AM
schmidtj's Avatar
Dealer checked the pressure and said it was fine.
Thanks all.
Old Aug 23, 2011 | 09:22 AM
wwest's Avatar
Camry in an unusual attitude just prior to indication, or FAST/TIGHT low speed turn and sump oil "sloshed" to one side..?
To conserve energy many new cars are now using a variable displacement engine lubricating oil pump. If the Camry hybrid is making use of that technique the displacement control may have stuck in a low volume position briefly
Old Aug 23, 2011 | 10:40 AM
schmidtj's Avatar
In this case the road was straight and level.
I was below 40 mph but don't know/remember if I was in
EV mode or not prior to the event.
When the low oil pressure indicator came on
I believe the engine was actually running but may have
just come out of EV mode but I am not sure of that.
I think when (if ever) I get an answer to why/how I got the error
indicator but it wasn't logged an actual cause can be determined.
Tnx,
J
Old Jun 30, 2012 | 12:10 PM
csmith427's Avatar
[2008 Toyota Camry Hybrid w/ 75K] I just had a similar incident for the first time. Driving 25mph on straight, level road in EV mode the 'low engine pressure' triangle lit up and the chime rang once a second before the engine kicked in. Since the alarm occurred while the engine was still off, I am chalking it up to a fluke. Oil was recently changed and is still showing full. The alarm has not occurred while the engine was actually running.
