AC odor TSB
Old 07-20-2010, 01:03 PM
beone's Avatar
Default AC odor TSB
So I took my 2009 TCH in for the TSB to replace the evaporator coil to get rid of the odor, but now I wish I didn't. The air conditioner is not as cold as it was before, it's cool, just not cold. Service manager said all the readings are in spec, "it's just hot in Dallas". Duh, yeah it was just as hot before I took it in. Anybody else have this problem after the replacement? He also said that no refrigerant needed to be added since it's a closed system? But I thought I saw on another forum that listed all the parts for the TSB and refrigerant was one of them?
Also my NAV/GPS doesn't work anymore, have re-calibrated several times, works for a while then it gets "lost" and thinks it's somewhere else. Since they scratched the screen, they put in a whole new unit today, after waiting a week for the part. Drove it for about 10 miles, was working fine then it went wacko again.
And to top it off, I have lots of dash rattles now, this is after the 2nd try of "fixing" them after the coil replacement. So now I get to take it back in again so they can remove the dash to try and figure out the NAV issue.
I really liked my car before all this, maybe I should have just lived with the stink.
Old 07-20-2010, 02:32 PM
rburt07's Avatar
Default Re: AC odor TSB
You might consider buying a cheap temperature 'meat probe' from any kitchenware department. Stick it in the center vents of a known other car with a good working AC. Then compare it to your 2009 TCH.
I would drive each car for about 15 minutes to allow the cabin to cool down. Make sure your recirculate button is lit up. No sense in bringing in outside 95 degree temperatures while trying to cool the cabin off.
You should read 38-45 degrees just inside the vent. You may read a little higher on very humid days or if the outside temp is 100 or higher.
The mold in the coils the dealer removed could be caused from a stopped up evaporator drain hole. After parking for a while you should see a water puddle under the car. It's usually visible by looking casually under the passenger side door.
I have noticed the TCH along with other cars I have owned, does not cool as well in slow city traffic (15 to 30 mph) as when driving at 40 to 50 miles per hour.
Old 07-20-2010, 03:51 PM
wwest's Avatar
One of the methods for alleviating the A/C odor involves coating the evaporator with a thin nylon porus film. An anti-microbial chemical, fungicide, is then embedded within the pores of that film.
The coating, obviously, will reduce the cooling efficiency of the evaporator vane cooling surface areas.
It's not possible to replace the evaporator without "draining" or losing the refrigerant. Or did they simply spray coat, inplace, the existing evaporator..?
Old 07-20-2010, 03:57 PM
wwest's Avatar
I would drive each car for about 15 minutes to allow the cabin to cool down. Make sure your recirculate button is XXX lit up. No sense in bringing in outside 95 degree temperatures while trying to cool the cabin off.
With the new automatic climate control systems the only way to check for FULL cooling capability is to measure the outlet airflow with the system set to the coldest setting, lowest blower speed, and recirculate mode.
Old 07-20-2010, 07:10 PM
rburt07's Avatar
Thanks willard for the corrections. I edited the recirculate light to on. I sure did overlook setting the AC to Hi cool.
Old 07-21-2010, 07:42 AM
SanAntonio Joe's Avatar
Agree with the previous posts. If the coil was replaced, draining and evacuating the system before recharging is required.
If your service rep told you they didn't change out the R-134a, then ask him EXACTLY what they did. This dealership sounds as if Moe, Curly and Larry are doing their A/C work. Nyuck, nyuck!
Also, it really sounds like it is time for you to find a new dealer to work on your car.
Joe
Old 07-22-2010, 12:30 PM
beone's Avatar
Well they finally fixed the NAV, it seems everything didn't get plugged back in like it was supposed to be. And after complaining about the AC it magically is cold again, but no mention from them that they did anything. So yes I will be searching for a new place for maintenance. The guy asked if I could just be so kind as to "misplace" the survey that's coming my way.
Old 07-22-2010, 04:41 PM
rburt07's Avatar
Thanks Bryan for you update.
That's funny, by saying that, he sure gave his so called quality service away.
Any serious work you may need from toyota, try asking for a 'certified' technician to do the work. They are sent to the toyota schools and are the more experienced mechanics. At least one has to have completed the hybrid school to specialize on the hybrid systems.
Old 07-22-2010, 06:09 PM
wwest's Avatar
"...try asking for a 'certified' technician..."
You're kidding, right..??
Those guys make, can demand, too much money to be employed by a dealer, especially in this economy.
Old 07-22-2010, 06:23 PM
PLEASE fill out that survey and send it in! That is the only way dealerships like his get 'motivated' to do it right the first time.
A dealer told me that ONE bad survey knocks them off of their goal of 100% CSI, and is a HUGE deal with management.
Also, PLEASE go to this Web site and write them up for their poor service:
http://www.dealerrater.com
Finally, if you are tempted to not write them up for their poor service, just imagine if that same tech that did a half-baked job on your car hooking up the NAV works on someone's ABS, traction control or air bag module next. NOW suddenly 'getting everything hooked up right' is very important!
Joe
Sue M
03-07-2010 03:28 AM
CAH
Lexus RX 400h
04-16-2009 09:58 AM
ToyotaGoblin
07-08-2008 07:03 PM
LEAKYTCH
05-19-2007 01:17 PM
reza
03-30-2007 10:35 AM
