2012 TCH inverter coolant capacity
Just curious, what is the capacity of the inverter cooling system? I'm curious if it would be "good enough" to suck the coolant out of the reservoir a few times (and replace it), similar to what some people do with brake fluid. I'm guessing the answer is no, but you never know...
Yep sounds like it. I assume I can just use the maintenance mode to run the pump after draining it?
Vic Doucette
Toyota Highlander Hybrid
Aug 29, 2015 05:30 PM
GeorgiaHybrid
Feb 5, 2015 07:27 PM
