2009 Plasma Cluster Not Working
Old Feb 25, 2014 | 04:01 PM
kawika72's Avatar
Default 2009 Plasma Cluster Not Working
Displays nothing, controls not functioning. Car was unused for a long time (months). Kept battery charged (slow charge - battery keeper). Car starts and runs, but no AC, heater, blower or outside temperature display. Everything else seems to work OK. Checked all AC fuses. Am I missing a fuse that powers plasma cluster?
Very, very low mileage for a 2009 (less than 50K).
Old Feb 25, 2014 | 05:45 PM
GeorgiaHybrid's Avatar
Default Re: 2009 Plasma Cluster Not Working
Try checking position 32 in the fuse block under the hood (labeled HTR with a 50 amp fuse)
Old Feb 26, 2014 | 11:55 AM
kawika72's Avatar
OK, got it to work (somewhat). First, it never displayed anything. Powered OFF and back ON - it displayed & worked for a few seconds. Powered OFF and back ON - displayed and worked a little longer. Kept doing this and it started working longer. Now, just came back from an errand and it worked all the way. Don't know what causes this, but I'm guessing that I need to use my car more often to prevent this kind of failure.
Old Feb 26, 2014 | 12:59 PM
You must live in a COLD climate for that to happen. The display can get a little squirrelly if they have a long cold soak.
Old Feb 26, 2014 | 01:22 PM
kawika72's Avatar
Nope, I'm in Hawaii. I think it isn't a display/control problem. It is more like a problem with the AC system or AC compressor relay. Seems if the AC is not working, the climate control won't work. I guess if the car isn't used for a while, the AC sensors/relays get affected. Sorry, but not very dependable for a Toyota product. Well, it is working for now.
Old Feb 26, 2014 | 03:20 PM
litespeed's Avatar
Professor Emeritus
That's a bummer! At least you got it working for now... They "don't make them like they used too", thats for sure!
BTW... The control display is just a plain old LCD display. Nothing at all special about it.
"Plasmacluster" refers to the air purifier located in the drivers air conditioning vent. Something about Positive and Negative Ion's or some gibberish. I remember reading that somewhere in the owners manual when I bought ours.
Old Oct 17, 2016 | 06:02 PM
Charliekriskate2177's Avatar
Default Re: 2007Plasma Cluster Not Working
It lights up but displays nothing boyght another one same thing lights up no display i would appreciate someones help
Old Oct 5, 2019 | 06:04 AM
pals4fero's Avatar
Where you able to sort out this problem? Please I'd appreciate an urgent response, as I'm having similar problems here.
AndyB
Apr 2, 2009 11:26 AM
jpezz
Sep 8, 2008 07:08 PM
Archslater
May 31, 2006 10:28 AM
bigbearballs
May 1, 2006 07:54 PM
kaymack
Dec 18, 2005 10:34 AM
