C1018:46:ab
![Default](https://electricvehicleforums.com/forums/images/icons/icon1.gif)
Ugh so here again with a 2009 FEH issue so traction light came on and break light came on and breaks became sponge. Ran codes and all I got was this perma code, tried clearing and resetting and nothing. Looked it up and thought it was a master cylinder issue but ended up changing the **** thing and same issue persistent. Found a reddit post that sounded reassuring but with a power bleeder at 50PSI still no resolution. Also did the Forscan bleeding procedure nothing then the module reset and get a error loop. Definitely stressing over this issue so any help in pointing me to the right direction would be appreciated.
