2007 vue greenline 98000 miles P0121 code
Old Feb 7, 2012 | 08:33 PM
RodC111's Avatar
Exclamation 2007 vue greenline 98000 miles P0121 code
Hi,
I just complete the idle learn process after cleaning the throttle body. So, now I have no dtc's but when using curise the tachometer keeps moving between 2000 and 3000 rpms.
Any Idea?
Thanks,
Rod
Old Feb 9, 2012 | 05:43 PM
Hillbilly_Hybrid's Avatar
Default Re: 2007 vue greenline 98000 miles P0121 code
Flat road? Speed set point? 3000 rpm on that dual overhead cam engine is not a big deal. It still has a step gear transmission and locking torque converter. So the terrain, how much stuff in car, and vehicle speed will be very helpful here.
2000 to 3000 seems a little outside the range of a locked or unlocked torque converter.
It might be downshifting.
Old Feb 10, 2012 | 07:52 PM
RodC111's Avatar
Additional info. Flat road running at 45 mph for 5 miles (just today 02/10/12). tach moving up and down every second or two and "ECO" light going on and off. This is while using 'D'. If I shift to 'I' (intermediate) the problem goes away.
Old Feb 11, 2012 | 09:12 AM
It sounds like "hunting" the step gear transmission and engine looking for an operating condition. Did you try turning off the ECO button too. Shifting to 'I' will restrict change the upper gears available like overdrive. I don't think anything is broken but most of us older guys that grew up driving John Deer (big push rod) engine powered cars are not used to tachometers above 2500. I went through a similar situation on my sisters 5-speed manual Vue. She lived in Park City and worked in Salt Lake City. She wanted to go over the pass in overdriv). It' ok to let it rev a little. Maybe check owners manual on the ECO and 'I' settings too.
Old Sep 23, 2012 | 12:59 AM
Mark492's Avatar
Yeah, turning off the ECO button may be help...
Old Sep 23, 2012 | 01:00 AM
Mark492's Avatar
..and if you have the manual it also may be help you.
highlanderhybrid
Saturn Vue Green Line
Aug 21, 2007 04:38 AM
dunkin
Website Questions & Input
Aug 7, 2007 06:16 PM
DRD T-bone
Mar 5, 2007 01:07 PM
Saturn Vue Cleveland
10
Nov 25, 2006 06:41 PM
