Engineer vents -- methodology
Hi folks,
Recently someone posted a rule of thumb for expected MPG vs miles per hour for a Honda Civic Hybrid and it 'set me off' about the absence of MPG vs MPH charts for all of our hybrids. Fundamental to all science is to have a benchmark, a baseline that establishes exactly how something works. This leads to insights when the measured values don't match theory and allows us to experiment and know if we are seeing a real change or some artifact. It is how engineering works and what attracts me to GreenHybrid.com.
What gauls me is the apparent lack of standard day (or any day) charts of MPG vs MPH for all hybrids like I do for the NHW11 Prius (see below.) With these charts, I've found notches where there are local peaks and valleys. I've used it to quantify:
Empirical knowledge, the grist of engineering and science, takes more. It isn't that hard to baseline a system but the benefits for subsequent experiments far and away outweighs the cost. The alternative are anecdotal reports and 'one time' experiments without a control and these are the feedstock of TV infomercials and advertising.
The GreenHybrid.com database is better than not having a database. We have gained insights about vehicles and within each model, temperature and trip duration effects on mileage. In the case of the Prius, we've also gained insights about the variable capacity fuel tank. What is missing is a simple way to map MPH vs MPG for each model hybrid.
Engineering teaches that the experimental methodology is critical to avoiding serious errors and mistakes. It is what lets us quantify effects and make plans that have a chance of success. So that is why I remain frustrated by the absence of MPG vs MPH charts for other hybrids. A 'rule of thumb' is better than none but begs the question of why not do the job right and actually measure MPG vs MPH and plot out the data.
All it takes is to get on the highway and when the temperature is 65-75F (or close enough) on a low wind day (or close enough) and just set the cruise control at one speed for an hour or so and then read out the MPG. That is all it takes to get one data point in an MPG vs MPH curve. When two or more observations like these give the same value, we have credible data and gain insight about how our various vehicles perform.
I just get so frustrated because short of buying one-each of every hybrid that exists and 'doing the experiment,' I don't see any effort to baseline our vehicles. The one HCH report was better than none but my frustration is how much better would a full MPG vs MPH curve. Having such data is so much better than just anecdotal 'buzz'.
Bob Wilson
ps. All of these charts used standard instruments found in every hybrid and in some cases, just gas receipts and trip meter mileage. All it takes is the patience to record the data and plot it on a graph:
First MPG vs MPH Chart
Improved Chart With Theory Drag
Hill Climbing Chart
- tire pressure effects
- oil fill level effects
- 42 miles per hour transition
- bump in MPG from 55-70 miles per hour
- temperature effects
Bob Wilson
Hill Climbing Chart
Hey - I posted an HCH speed vs FE chart a couple of months ago that I thought was ok for 55-70mph. It had pretty low noise per condition considering each condition was <1 mile and the whole test took under two hours.
Claiming that the speed vs FE curves I posted are "baseline or control" would have been inappropriate - they are just what happened during my test. I did, however feel pretty confident in stating that both speeds above 50 and AC use "kills" FE.
Compared to what has been published in the past, this is great. Look, I have no problem if someone posts different Prius data because it means there is something different that needs to be understood. Now if we get similar data, that is good too because it means two of us are seeing the same thing. That is how science works.
Bob Wilson
https://www.greenhybrid.com/discuss/...c-vs-fe-14566/
I missed where you said there was an HCH speed vs FE "rule of thumb" posting.
best regards,
best regards,
BTW, I'd forgotten about your posting on the MPG vs MPH chart. Thanks for the reminder.
Bob Wilson
RockMonkey
Website Questions & Input
Apr 30, 2007 11:09 AM
fernando_g
Apr 7, 2006 10:39 AM
