Aspartame
Originally Posted by Schwa
Dude, I recommend you read up on Aspartame. It breaks down in the body to methanol and formaldehyde that gets into your brain and causes real damage over time. Jet pilots are forbidden from drinking diet sodas because of the aspartame content. I highly recommend keeping that stuff out of your diet if you are at all concerned about your health.
I drink 2-3 Diet Cokes daily, so maybe I just got pushed enough to swear them off. The FDA will investigate.
Originally Posted by Delta Flyer
For years, people have said aspartame is an unhealthy sweetener, but this recent study seems to prove it causes cancer.
As far as cancer goes, one of the most effective known preventative substance occurs naturally in certain foods, but most of them are missing from our westernized diet. This whole mystery was solved years ago, but to this day hardly anyone knows about it, so they can't consciously choose foods that contain the compound 'vitamin B17'. Many studies of aboriginal tribes with no cancer history to the present day found that their diets were high in plants with B17, and when they leave their environment and consume 'normal' food they are just as likely to get cancer as most of us are. There has been a lot of high power drug company studies where they try to treat a patient with B17 extract, but usually only after the patient doesn't respond to surgery, chemo and radiation (in which case their immune system is thrashed) and in no way disproves any of the claims of successful use in studies, but in any case it wasn't meant to be a "cure" so to speak, although like finding a cure for scurvy it's primarily a dietary issue, but also as important are the triggers that 'set off' cancer in the body. Info on the foods with B17 can be found here: http://www.worldwithoutcancer.org.uk...ventative.html and some info about the history of it as a cancer therapy http://curezone.com/diseases/cancer/laetrile.asp
Sure, it will cause cancer as long as you drink at least 1000 diet cokes a day, every day, for 5 years. Did you know most vitamins are fatal too? Everything will kill you if you have a hundred or ten thousand times the proper dosage. Radiation can kill you too, and we're exposed to plenty of radiation every day also. It's all about the dosage.
Should have mentioned that the rats had "normal" does.
Years ago, an Englishman drank a gallon of carrot juice, but what killed him two weeks later was a bottle of Vitamin E daily - body could not get rid of it like the juice. His body was bright yellow at death.
No, he was not named Homer Simpsn.
