Requesting Help Gathering RX Info
Old May 4, 2005 | 04:25 PM
Jason's Avatar
Site Founder
Default Requesting Help Gathering RX Info
Would anyone be willing to help out and please compile the necessary information to complete the hybrid lineup column for the RX 400h? It would be a great help. Thanks.
Old May 4, 2005 | 07:31 PM
xcel's Avatar
Default Re: Requesting Help Gathering RX Info
Hi Jason:
___If no one steps up, I will get you the RXh’s specs by late this weekend. I am still in the midst of a very busy month and will not recover until Sunday or Monday …
___Good Luck
___Wayne R. Gerdes
___Waynegerdes@earthlink.net
Old May 4, 2005 | 07:34 PM
Jason's Avatar
Site Founder
Sure, I'd appreciate that. And, I apologize for never finishing the Escape Hybrid 100%. I know you gathered all that information for me once before. It just got pushed down on the priority list, but I've gotten most of my Todo list taken care of and this is rising to the top!
I'll also need to double-check that all the figures are from the same sources. Acceleration, etc. I'll likely start pulling these from the manufacturer sites so it's a bit easier. I also got rid of the options checklist because it was getting too large and complicated. You can only compare so many features before it gets rediculous.
Old May 9, 2005 | 05:12 PM
xcel's Avatar
Hi Jason:
___Here you go …
Code:
Manufacturer: Toyota
Available years: ‘06 +
Type: Full Hybrid
Hybrid System: Hybrid Synergy Drive
Base MSRP: $49,185 incl. destination
Style: SUV
Seats: 5
Doors: 4
Emissions Rating: SULEV
FE - eCVT: 31/27/29
Maximum Charge: 7.3 seconds
Minimum Charge:
CVT
Net Power: 268 HP
Engine Power: 208 HP
Motor Power: 167 HP (Front)/68 HP (Rear)
Net Torque: 247 Ft.-Lb’s (Front)/650 Ft.-Lb’s (Rear)
Engine Torque: 212 Ft.-Lb’s
Motor Torque: 3,500 Ft.-Lb’s @ 0 RPM ???
Voltage: 650 V
Liters: 3.3 L
Total Cylinders: 6
Min Cylinders used: 6
Turning Diameter: 37.4 ft.
Gasoline Type: Regular Unleaded
Tank Size: 17.2 gallons
Drag Coefficient: .35
___Good Luck
___Wayne R. Gerdes
Old May 9, 2005 | 05:43 PM
Jason's Avatar
Site Founder
Thanks. The Lexus is all done:
https://www.greenhybrid.com/compare/lineup/
Any idea where that Escape info is you once gave me?
Old May 9, 2005 | 08:42 PM
xcel's Avatar
Hi Jason:
___I posted this just before the crash and it disappeared? Here you go again.
Escape HEV specs …
___Good Luck
___Wayne R. Gerdes
Old May 9, 2005 | 08:44 PM
Jason's Avatar
Site Founder
And what a crash it was!
I noticed a couple things "disappeared" too. It's possible some backup file was activated, though I'm not sure yet. What time did you post?
Old May 9, 2005 | 09:09 PM
xcel's Avatar
Hi Jason:
___Maybe around 08:00 PM CST?
___Good Luck
___Wayne R. Gerdes
mp_oif2
Mar 3, 2006 12:10 PM
Wolfman
Events & Gatherings
30
Nov 1, 2005 10:56 AM
mrv
Events & Gatherings
Jul 28, 2005 07:43 PM
john1701a
Events & Gatherings
Feb 1, 2004 06:19 PM
