Journalism & The Media Television, radio, movies, newspapers, magazines, the Internet and more.
Excellent 2010 Prius Technical Description
Old 03-16-2009, 04:16 PM
bwilson4web's Avatar
Engineering first
Default Excellent 2010 Prius Technical Description
Hi,
http://missionzero.org/categories/1-...0-Prius-Hybrid
. . . The multifunction gearset incorporates two sets of planetary gears: a power-split planetary gearset and a speed reduction planetary gearset. Both gearsets share the same ring gear, which drives the transaxle’s counter gear. The sun gear of the power-split gearset is connected to the 42 kW motor generator 1 (MG1); the planet carrier is connected to the engine. In the speed reduction planetary gear set, the sun gear is connected to MG2, the carrier is fixed, and the ring gear connects to the counter gear. A parking pawl is also part of the assembly, which is connected to a differential with a final drive ration of 3.267:1.
I have been going nuts trying to find this one bit of data. The whole write-up is one of the best collections I've seen.
Bob Wilson
merlinsmommy
06-15-2010 09:15 PM
stevenvillatoro
Honda Insight
04-28-2009 08:40 PM
Billyk
04-20-2008 02:33 PM
nicst47
11-27-2007 05:02 PM
bernt
10-29-2006 05:58 AM
