Electric Vehicle Forums
-   Introductions (https://electricvehicleforums.com/forums/introductions-23/)
-   -   Issue with Honda Fit Shuttle Hybrid IMA (https://electricvehicleforums.com/forums/introductions-23/issue-honda-fit-shuttle-hybrid-ima-32911/)
brianmoonga Jan 20, 2022 11:11 AM
Hello everyone, I am excited to be part of this forum, learning a lot.
I own a Honda Fit Shuttle Hybrid 2011 model-GP2, it has done about 100 thousand kilometers, and recently the IMA light went on with this message "I can't charge."
There is a fuse that I discovered got blown, and after replacing it, the problem has not gone away as fuses have been repeatedly blown. I have also discovered that sometimes the fuse does not blow away the right ways, but does so after I cover more than 15 kilometers. A recent diagnosis on the car shows there is an inventor issue, and unfortunately, the Honda dealership in Lusaka seems not ready to help me, and so are the other auto-electricians that I have consulted, I think that they do not yet have skills of working Hybrid vehicles, which is a pretty new technology here.
If anybody has had this issue and they solved it, kindly let me know. I can drive the vehicle a little bit before the 12V battery discharges and all hell breaks loose.
Thanks!
https://cimg9.ibsrv.net/gimg/www.gre...ae53a41b2.jpeg
https://cimg1.ibsrv.net/gimg/www.gre...4b04788d3.jpeg
https://cimg3.ibsrv.net/gimg/www.gre...fe74d1c4b.jpeg
brianmoonga Jan 21, 2022 10:01 AM
Re: Issue with Honda Fit Shuttle Hybrid IMA
Thank you, Grace.
Madu Mar 14, 2022 01:08 PM
Hi there, have you fixed the issue? I have the same problem here. Fuse 53 keep blowing.
brianmoonga Mar 15, 2022 07:52 AM
Hey, not yet fixed it, the problem is caused by a weak battery that has to be replaced, so I have bought 2 pairs of the 7 pairs needed, I am advised by the technician that those will solve the problem, however, the ideal solution is to replace all batteries, eventually. Each battery costs $70 from a Chinese dealer who will soon ship them to me. The shipping is expensive because there are few forwarders willing to transport a NiMH battery. I have all the information if you need it. We should be changing the batteries two weeks from now when they arrive. The car covers a total of 26 KM before it blows the fuse.
S Keith Mar 15, 2022 08:52 PM
Your "technician" is wrong. That code is NOT related to the IMA battery at all.
You have
1) a blown fuse that's disabled 12V charging.
2) a bad battery cooling fan that's cause the fuse to blow.
brianmoonga Apr 30, 2022 01:54 PM
Hi, just curious to know if you fixed your car's IMA charging problem. You were right the battery did not help, P1634 code says Motor Power Inverter signal circuit (temporary). It keeps blowing fuses. I think Honda really had not done a good job, this issue looks like it's extremly common.
S Keith Apr 30, 2022 03:19 PM
When did you replace the battery fan?
brianmoonga May 1, 2022 04:39 AM
Hi, we have not replaced the fan yet, hard to find online. Wondering if you fixed yours.
S Keith May 1, 2022 08:55 AM
This is your thread. You started it. You need to replace your blower. Until you replace the blower, you will continue to have this problem.
Munyih Aug 20, 2023 11:26 AM
​​​​​​ Question-Getting error IMA for Honda shuttle hybrid 2014. What could be the cause?
