hello everyone
Hello everyone my name is Rapali.
I need an advice
I was checking the hybrid coolant level and see that it has dropped below low, cold morning before starting engine. Is it ok just to add more fluid or would you recommend a fluid change?
If changing the fluid do I pour in exact same amount that came out or I should pour until I reach Max limit?
The coolant being low, does it indicate that anything else has to be checked?
Thanks!
I need an advice
Thanks!
welcome
