Hydrogen cells and cold weather
Old Oct 29, 2011 | 01:37 PM
joelstitch's Avatar
Default Hydrogen cells and cold weather
I am planning on adding a hydrogen conversion to a few cars but was wondering if there are any issues with the hydrogen conversion on cold weather? I'm talking about Minnesota weather, so it gets really cold. What do I have to do to keep the conversion working in the winter?
Old Jul 3, 2012 | 10:11 PM
DJWorm's Avatar
Default Re: Hydrogen cells and cold weather
If your thinking of running an HHO system which is basically H2O with a potassium elecrolyte it should be good to -15*F but a type of antifreeze may also be warranted....however placing propolyne glycol or ethylene glycol thru an electrolysis process and then inducting it into the engine to be burned is NOT a good idea. DON'T use regular antifreeze. However you can use isopropyl alcohol (rubbing alcohol). I'd check with the manufacturer of the unit for advice and concentration.
Col182
Oct 7, 2014 04:56 PM
Rogstar
Jan 31, 2006 05:20 PM
Jason
Hybrid & Related News
Aug 16, 2004 07:28 PM
