Insight Tires
Old May 22, 2006 | 09:04 PM
TheGreenMachine's Avatar
Default Insight Tires
I need new tires for my Insight and I don't know whether I should by the same tires or by some other brand. Has anybody used different tires?
Old May 23, 2006 | 06:01 AM
tedj's Avatar
Default Re: Insight Tires
The only tires I would consider other than the Bridgestones RE 92's are the Dunlops s31's used on the Fit and then only with the 165 mm size. Everything else has been a real mileage drag.
Old May 23, 2006 | 06:39 AM
Bjaardker's Avatar
Never used anything other than the OEM tires. I couldn't see any reason to do it. First, you would be putting a tire that is the wrong size on to the car. Second, I couldn't find a cost justification. The Bridgestone oem is pretty reasonable at about $55 a tire.
Old May 23, 2006 | 06:57 AM
Delta Flyer's Avatar
Banned
I'd scope out Firestone dealerships that carry these rare tires.
If you change the tires, the odometer and mpg display will be inaccurate by more than a little bit.
Old May 25, 2006 | 07:54 AM
kinsight's Avatar
I made the mistake of replacing OEM tires with Michelins and my mileage droped from 70 to 65 within a few months. Had tread separation with the Michelins and went back to the Potenzas and my mileage is steadily climbing. I purchased the Potenzas at Discount Tire.
oldsnail
Honda Insight
18
Sep 12, 2011 07:36 AM
TonyInsight
Honda Insight
May 5, 2011 04:25 AM
insighthopeful
Honda Insight
May 1, 2008 10:22 AM
Rick in Yuma
Honda Insight
22
Feb 28, 2008 01:33 PM
Sledge
Honda Insight
May 25, 2006 07:48 AM
