"Check Engine" warning light
Old Sep 18, 2005 | 07:59 PM
Ricco's Avatar
Default "Check Engine" warning light
My Insight, with just over 40K miles, lit the "check engine" up. Calling around, the Honda Dealer Service Departments wanted an average of $100 just to plug the probe into the engine to diagnose. I had read on InsightCentral.net that this had been a problem with some Insights--assuming the car cap had been replaced properly after fueling-up. Turns out that the (LAF) oxygen sensor can send a false-report a problem to the engine control computer (ECM). Honda Dealers at first were replacing the sensor under the 3yr/36K warranty, but later focused in on the ECM, changing that out. My other problem iwa that my car is out of the warranty period, and I didn't relish paying $100 for a possible design flaw. When I mentioned that possibility to a Dealer Service manager, who told me he had never heard of that. Scratching him off my list, I reset the computer by disconnecting the negative battery cable for a few minutes, then reconnected, thinking that if there really was a problem, the light would come back on. That was 300 miles ago, and no light yet. More on that can be found here:
http://insightcentral.net/KB/faq-com...ml#CheckEngine
Still kick'n!
Ricco
Old Sep 19, 2005 | 08:29 AM
tbaleno's Avatar
Default Re: "Check Engine" warning light
You know autozone will hook a computer up to your car to get the codes for free. They can also clear codes. And if there is a faulty part gladly sell it to you for less than the dealer. I'm glad you got rid of the light by disconnecting the battery. Nice job on saving yourself some money.
Old Sep 19, 2005 | 09:57 AM
Ricco's Avatar
Thanks for the tip, as I'm a Newbie, having only had my Insight a short time.
Ricco
stoshiro
Jan 12, 2021 03:11 PM
AudHCH
Mar 1, 2014 10:27 PM
cak615
Oct 28, 2013 08:11 PM
funnd
Aug 1, 2012 12:23 PM
SadCarTime
Jul 9, 2012 08:05 AM
