What is a good PSI to have my tires at in 50-60(F) Degree weather?
Old Apr 7, 2008 | 09:14 AM
MrHockey20's Avatar
Default What is a good PSI to have my tires at in 50-60(F) Degree weather?
I have the stock tires on my 2008 HCH. I do not know much about PSI but I know the higher the PSI the better gas mileage. I don't want to put the max psi on the tires because im afraid of when it gets to 80 here it might expand to much and ruin the tires.
Any suggestions will be helpful. Thanks!!!
Old Apr 7, 2008 | 09:21 AM
giantquesadilla's Avatar
Default Re: What is a good PSI to have my tires at in 50-60(F) Degree weather?
I keep mine both at 42 PSI. Everyone has their own opinion on how full they want their tires. By the time the temp rises 20-30F your tires will probably have lost some air. It is also a good idea to check your PSI every few weeks.
Old Apr 7, 2008 | 10:06 AM
mmrmnhrm's Avatar
Wo ai Zheng!
Same pressure all year for me... 50 PSI across all four tires, regardless of outside temp. Yes, for those of you watching at home, this is slightly above max sidewall.
Old Apr 7, 2008 | 12:57 PM
Hot_Georgia_2004's Avatar
I ran my last tires at 51PSI for the life of the tires. The Dunlop's were rotated every 15K miles, alignment every 20K and the tires lasted for 88,000 miles.
Not bad!
Old Apr 7, 2008 | 01:35 PM
MrHockey20's Avatar
Not bad!
I'm in Michigan where in the summer it is usually in the 70-80's. What would you guys suggest as a PSI for that?
Old Apr 7, 2008 | 07:09 PM
spinner's Avatar
The same pressure, year round. Something above minimum cold tire pressure as indicated by your manual or the sticker in your door jamb or gas cap. Increase to compensate for load. Higher pressures with a lighter load means reduced traction. Don't sacrifice yours or anyone else's safety on the road to save a bit of fuel.
haroldo
Apr 12, 2011 06:18 PM
noflash
Feb 13, 2007 06:21 PM
moosh
Apr 3, 2006 12:05 PM
mexiken
Mar 11, 2006 06:55 AM
