Warning Light Gas Low
I was wondering how far you could drive, after the warning light comes on.
According to my calculations, based on the quantity to fill at the time my light came on versus the tank capacity. There was 7 liters left in my tank, (or 1.5 imperial gallons or 1.8 us gallons). This based on a 47 liter tank as per Honda specs for the 2006 Civic Hybrid.
Over my past 16 fill-ups, I have averaged 57.7 MPG (imp), or 48.1 MPG (us) or 4.89(liter/100Km). That said; I should be able to drive 86.5 miles after my light comes on, or about 139.2 Km . The furthest I have driven is 30 miles or about 50 kilometers before refueling without any problem.
How far have you driven in your 2006 HCH after your low fuel warning light came on?
Re: Warning Light Gas Low
I've managed drive 47km after the warning light appeared. If I recall, it became a 39 liters fillup (Husky/Mohawk 10% ethanol blend).
I typically avoid driving on an empty tank for very long. For me the risks are high and the benefits are non-existent.
Regards;
MSantos
Regards;
MSantos
The problem is you don't know exactly how much gas was in it when it was "full".
If the tank holds 47 liters how do you know that is exactly what went in there?
The pumps shut off based on back pressure.
How do you know it is calibrated for a back pressure that corresponds to exactly 47 liters?
Originally Posted by jonmatt4nr
I believe the manual states that the light comes on when there are approxmilately 1.7 gallons left in the tank.
Cheers;
MSantos
I regard the warning light as just that - a warning. I then drive until no bars are showing, then I fill up in the next 5-10miles. I always have at least 50 miles of sensible motoring still left.
Thanks to everyone for you input and personal experiences.
After driving straight home a few weeks ago on a 750-mile trip, during the night through rural areas, I have to admit, I was nervous after my fuel light came on. Its comforting to know I still have at the least a good hour of sensible highway driving.
Again, Thanks to you all.
In my car, the fuel light comes on quite consistently when there is about 9 liters left, which means I can drive 180 km more. Last time I stretched it 140 km, and then filled 46.37 liters. My manual says the tank holds up to 50 liters, not 47.
