To ULEV or not ULEV?
I know that ULEV stands out for UltraLow Emissions Vehicle, am I right?
However, I've seen other posters mentioning something like PZEV or something like that.
What is this? What is the difference compared to an ULEV vehicle?
Sorry for the dumb question.
PZEV stands for Partial Zero Emissions Vehicle that is also rated SULEV (Super Ultra Low Emissions Vehicle). SULEV/PZEV rated vehicles emit lower amounts of Hydrocarbons, Nitrous Oxides, and Carbon Monoxide than ULEV rated vehicles.
Not all states have PZEV rated vehicles available.
See Wikipedia's definition of SULEV here:
http://en.wikipedia.org/wiki/SULEV
There is a range within each emission category, but middle SULEV is about twice as clean as middle ULEV.
PZEV is SULEV + a gas tank that prevents evaporative emissions and a longer warranty for the emission related components.
ULEV/SULEV/PZEV are designations from the CA air resources board (CARB). The US feds have their own set of standards (in tier/bin categories) that are less stringent than California's, which has led about 10 states (West coast , Niew England, NY, NJ) to use CA's requirements.
This EPA site is a very good place to use to include emissions considerations into your buying decision.
Good Luck, and kudos for caring.
-- ERic
-- ERic
Thanks all for your replies, but perhaps I should have asked my question a little different...
In the Civic Hybrid, what are the performance differences between the ULEV and PZEV?
I know, for instance that the gas tank's capacity is lower. But there may be something else, like not allowing the engine to run so lean, as lean burning may produce higher amounts of contaminants, specifically NOx....
thanks again, and happy coasting back home.
I'd much rather have a PZ myself but they don't sell em here. The warranty for the PZ is fantastic!
"The PZ has a smaller tank (I don't know why)"
My guess would be that the tank is smaller due to the extra width of the gas tank walls themselves, which would be there in order to prevent evaporative emissions.
well that's strange, i thought since it was 'partial zero emissions' that the pzev HCHs were able to run with the electric motor only and that the PZEV HCHs had that advantage, guess i was wrong
Hi All:
___If you are in the hunt for a new HCH (I would wait for the new 06 myself), I would pick up a PZEV. The issue is that Honda does NOT give you the longer warranty on the emissions equipment if it was not driven principally in the 5-clean states you purchased it in. I have never seen a challenge to this weasel wording but if I were ever to lose a CAT at 65K miles here in Illinois in my own Massachusetts purchased PZEV (one of those 5 clean states) and Honda would not cover it, I would be taking the matter up a little higher then Honda corporate if you know what I mean.
___In either case, if you are going to purchase new, drive to a state that has a PZEV available to you as the < $150.00 upcharge is easily worth it when you consider the emissions that a LEV/ULEV emits vs. the PZEV. The Honda PZEV’s (PZEV based HCH and non-hybrid Accord) are the cleanest mass produced automobiles on the planet other then the Natural Gas based – non-hybrid Civic.
___Good Luck
___Wayne R. Gerdes
___Waynegerdes@earthlink.net
___Good Luck
___Wayne R. Gerdes
Originally Posted by xcel
Hi All:
___Good Luck
___Wayne R. Gerdes
___Good Luck
___Wayne R. Gerdes
Originally Posted by Atomic Frog
Does the Civic Hybrid in PZEV form outclass (i.e run cleaner) than the 2nd generation Prius which I believe is also a PZEV?
