Questions on FAS
Ive been reading alot about FAS and it just doesnt seems safe to mess with the ignition switch while driving. I was thinking isnt there a way to trick the car into doing a Auto stop? If i did my research correctly, isnt the AS feature enabled when you are going 8mph> and come to a complete stop? Can you just trick the computer you are stopping(pressing the brakes) with a switch? or does the car actually knw you are at a complete stop? It just seems like there is an easier way than turnign off the car everytime.
Re: Questions on FAS
Hi Infinkc:
___You are right. Because there isn’t a button or an automatic way to make an IMA equipped automobile shut down above 20 mph and start back up automatically w/out dumping the clutch on a MT equipped one after a FAS, you have to live with a workaround or not have it available to you at all. If Honda did allow a shutdown and restart from any > 1.5 second let off of the accelerator to re-application of the accelerator, then you would have no problems other then meeting the coolant temp setpoints and using Econ or no A/C. Honda does know how fast the car is traveling if the electronics are live if that helps. ___Good Luck ___Wayne R. Gerdes ___Waynegerdes@earthlink.net |
