Mountain driving
Anybody have suggestions for getting the most on my upcoming trip to the Appalacians? Needless to say, it's quite different from my usual Ohio farmland.
Re: Mountain driving
Enjoy the scenery and ignore the mileage gauge - it will put you in a bad mood!
:-) (real answer - there is no easy way to get good mileage in the mountains! Just don't use cruise control as the mileage will be worse than without) Eric |
Eric, I see you're in central PA, which is just about where I'll be (Somerset/Berlin). Any use in using 'S' instead of 'D' while I'm on US-30 between Donegal and Bedford?
That's a bit further west than I am actually. I'm in the York area which is out of the really hilly area, we have more "rolling" hills here. I have never really tried to use the S position actually (or at least I have never TRIED to. I know that the car doesn't regen in S from the one time I slid the shifter past D and into S... took a few minutes before I figured out why I couldn't regen... ). Anyhow, Rt 30 at least where I am is pretty much a 55mph 2 lane highway. The mileage should be much better for than if you were on the turnpike or other highway during the hills. If I were you I'd just use Drive, and use the "drive with load" techniques described here. That's what has worked best for me on hills. You end up slowing down as you go up the hill, but as you go down the other side, you can kick the car into EV mode (100mpg pegged - no fuel being used) and "coast" and regen down the other side. Let me know how you do - I'd guess I'd get 45-50 under those conditions (When I can go slower in our rolling hills at 40 mph I have gotten up to 63 or 64 mpg for the 18 mile trip to the inlaws house)
Good luck Eric |
I have been able to climb several mountains in my travel for work and still end up with overall great mileage.My last tank was 57.2 mpg and it was as i call it my mountain run( Kane and Saint Marys Pa.).I have had my car for 2 weeks know and have just over 2000 miles on it.Just keep your speed and rpm's under control.
Harry,
That's great. Better mileage than I guessed for your driving. Sounds like the Civic is working out well then? Eric |
I live in Colorado and (as you would guess) do a fair bit of mountain driving.
Don't use cruise control when going up a long, steep grade. The assist will usually not come on, and the RPMs will just get higher and higher to maintain speed. Take it out of cruise, then to force the assist to come on, pulse the gas pedal and watch the assist bars rise. The RPMs will not rise as dramatically as when using the cruise. At least this is my experience, and I regularly get about 46 mpg. |
