Killing the Buzzers on 06 HCH
Greetings all, we take delivery of our new HCH later this week. Looking forward to all the great commentary and insights from folks here on the board. Sure have learned a lot already ...
This post is to ask if anyone has disconnected the buzzer(s) that come on an '06 (the ones that make a racket if you like to turn on the car before fastening your seat belt, open the door with the key in the ignition, etc.) Hopefully there is a single physical component that makes all these sounds so all can be eliminated by taking out one part. |
Re: Killing the Buzzers on 06 HCH
This post is to ask if anyone has disconnected the buzzer(s) that come on an '06 (the ones that make a racket if you like to turn on the car before fastening your seat belt, open the door with the key in the ignition, etc.) Hopefully there is a single physical component that makes all these sounds so all can be eliminated by taking out one part. Close the *&%#$ door, and fasten your *&!@!# seat belts BEFORE you turn on the %@$!! car... et voila!:lightbulb |
Wow, that was a harsh comment.
Tom in Austin, welcome to the forum. I do not think you will find anyone that has done that yet on an 06. There was a thread a while back about someone who wanted to do that on an '05. The general consensus of the members was that this was a bad idea due to safety concerns. I do not think anyone provided an answer for him. Usually folks here are very friendly |
It was probably not meant to be very harsh.
It expect it was meant to make a point while being humorous. Humor, especially sarcastic humor, is difficult to pull of on forums unless the writer and all of the readers know each other very well. You don't get the benefit of voice inflections, eye contact, facial gestures, or body language. These things are a large part of communication and without them it is easy to be misunderstood. |
I hope, and you probably are, correct. I was just trying to send a warmer welcome.
Clay |
Indeed.
This forum does have a very friendly tone, one of the reasons I like it here. BTW Tom, I used to also want to disconnect the buzzers. They really bothered me. I never did, I just ignore them or avoid hearing them by always buckling up and doing everything else the buzzers tell me. Maybe I'm just getting old. ;) |
-So, the problem with this situation, is that on almost all new cars, the buzzer is integrated into the electronics cluster. Before (and this is a guess) 1995 or so, most cars could simply have the beeper disconnected or the fuse to that component removed.
-For the door beeping to be disabled, it's just a small amount of electronics work to manipulate the sensor. -For the seat belt beeping, it requires a great deal of work to access the wiring harness and solder the wires together to complete the circuit and trick the system into thinking the seat belts are always triggered. There are resources on both through a Honda Element website, and a number of others on Google. Good luck. |
Oh yeah... If you disbable the door componenet be wary of these problems.
Thanks for all the input. I am hoping to just locate and deactivate the device that produces the buzzing sounds, not stop the electronics system from triggering the device. As someone said, traditionally the buzzing device was a discrete component you could find by listening for where the noise was coming from.
Once I figure it out, I'll post for any others that are interested. |
-Yeah, that would be advantageous, but therin lies the problem.
-Todays carmakers are integrating this device into the actuall electronics control system. Disabling the device would be akin to removing the foot to get after a bunion. You'd have to tear the entire dash apart. -With todays electronics it's nearly impossible to remove the beeping componenet, leaving the electronic sensor manipulation as your only real means of solving your problem. |
