Intake Valaves
Old Jun 9, 2008 | 02:04 PM
fuelmiser's Avatar
Default Intake Valaves
Hi Guys,
Just in the process of securing a new HCH II.
Thanks for the explanation , very cool and it's one time I don't mind being proven totally wrong.
Old Jun 9, 2008 | 04:56 PM
mmrmnhrm's Avatar
Wo ai Zheng!
Default Re: Intake Valaves
No. When the engine is in glide mode, both the intake and exhaust valves stay closed. The camshaft is independent of the crankshaft, so there's no reason why it has to keep moving. See http://www.hondanews.com/categories/957/releases/2781
(I used to have a really nifty movie, will see if I can find the link)
Edit: Found it http://world.honda.com/HDTV/news/2005-4050705b/
Old Jun 9, 2008 | 05:05 PM
Oiler's Avatar
Here is the video. Enjoy!
http://world.honda.com/HDTV/news/200...05b/index.html
Old Jun 9, 2008 | 07:22 PM
spinner's Avatar
The Civic Hybrid uses a 3-Stage i-VTEC valve control system that provides normal valve timing, high output valve timing and cylinder idling functions to the benefit of low fuel consumption, high output and greater electrical regeneration capabilities. The previous generation system in the 2005 Civic Hybrid uses 2-stage VTEC that provides normal valve timing and 3-cylinder idling. The 3-stage system adds high output valve timing and 4-cylinder idling. The high output valve timing contributes to the engines increase in output of 9 percent, while the added cylinder deactivation reduces pumping losses by 66 percent to help improve electrical regeneration capability by 1.7 times.
Old Jun 10, 2008 | 02:54 PM
holicow's Avatar
Originally Posted by mmrmnhrm
...The camshaft is independent of the crankshaft, so there's no reason why it has to keep moving.....
This is not quite correct. The camshaft is directly driven by the crankshaft by the timing chain, so it is rotating at all times. The action of the camshaft on the valves is what is controlled by the i-VTEC (by the rocker arms).
Old Jun 11, 2008 | 07:47 AM
mmrmnhrm's Avatar
Wo ai Zheng!
Doh! I stand corrected
billynjoanna
Jul 19, 2011 08:59 PM
krousdb
Jul 8, 2006 06:12 AM
rgx
May 8, 2006 07:27 PM
gonavy
Jul 6, 2005 12:59 PM
zadscmc
Jun 8, 2005 06:18 AM
