How fast do tires loose air?
Old Mar 9, 2006 | 05:04 PM
kenny's Avatar
Default How fast do tires loose air?
When I fill mine up I go to 40 PSI.
How long will it take for them to fall to 35?
Does it depend on how or how much I drive.
Temp?
Old Mar 9, 2006 | 08:08 PM
yojimbo's Avatar
Default Re: How fast do tires loose air?
It probably varies but mine seems to drop about 1 PSI a week. I usually check mine every 3-4 weeks. I keep them at 40-41 PSI.
Old Mar 9, 2006 | 08:41 PM
Hot_Georgia_2004's Avatar
I check mine weekly and they're usually 1-2lb off. Sometimes no change for weeks.
Old Mar 10, 2006 | 05:08 AM
kettleone's Avatar
They should not go down except for changes in temperature.
If you have them all set at the same pressure (using an air gauge), they should all fluctuate in unison. If one is down more than the others, it has a leak somewhere.
Old Mar 10, 2006 | 05:25 AM
gonavy's Avatar
There are far too many variables at work to state the answer for your case. All you can do is check them periodically- each fillup.
And find the stations near you that have free air, or keep a supply of quarters. Exxon usually has free air&water
flopshot
Aug 2, 2008 06:45 AM
Gretchen
Jun 25, 2007 08:44 AM
eeminbiole
May 15, 2007 06:55 PM
Hondasucks
Mar 13, 2006 11:48 AM
