Hey guys, new 04 hybrid owner
Old Jan 9, 2007 | 08:09 PM
carbnjunkie's Avatar
Tofu+hybrd= crazy fun!
Default Hey guys, new 04 hybrid owner
Hey guys, just got a 04 civic hybrid (72k) manuel, and i love it.
2 quick questions, the hybrid battery doesnt look like its charging all the way, it charges maybe 90-95%. Is that normal?
Also, when it is at the full charge, or almost full charge, the car doesnt always turn off (the auto idle stop - only maybe 20% of the time does it turn off.) Even when the car is warmed up, and its in neutral.
Any help would be great, thanks.
Old Jan 10, 2007 | 06:24 AM
cbxtc6's Avatar
Default Re: Hey guys, new 04 hybrid owner
Yes, 90-95% is about what mine will charge to.
If it's cold outside, say <30F, the autostop won't work. Also, try pushing the clutch pedal ALL the way to the floor to engage the autostop.
Old Jan 10, 2007 | 09:18 AM
Yup, I've only had the car for a couple days so far, so I will make sure to drive it more before making conclusions.
Any problems I should look out for?
The IMA system in my car is still under warrenty for 8k more, so if you can point any common problems I can look out for, that would be cool.
Thanks guys!
Old Jan 10, 2007 | 10:37 AM
alloyz's Avatar
I dont think I would be worried about any problem areas, its a Honda, they are for the most part VERY reliable - even the Hybrids.
Old Jan 10, 2007 | 10:40 AM
Thanks guys. I've heard bad stories about the auto CVT, but the manuel looks kosher.
You guys have a hard time finding air filter replacements? I ended up getting a dark K&N drop in online because of it!
Old Jan 10, 2007 | 11:06 AM
Sorry guys - one more quick question.
When does the timing belt have to be replaced? My car has 72k, and i bet
that the last owner didnt replace it yet.
Old Jan 12, 2007 | 11:43 AM
leahbeatle's Avatar
No major problem areas I'm aware of, though there is a class action lawsuit going on for all Hondas that alleges problems in the odometers- so your car may end up being under warranty for longer than you thought. The settlement provides for an extra 5% on the warranty, just fyi. check back a bit in the HCH threads for a discussion of this.
Old Jan 12, 2007 | 11:48 AM
Wow, thanks leah. appreciate that.
Old Jan 14, 2007 | 09:22 PM
Tim's Avatar
Tim
Enchanter, Enthusiast
Some of what you're asking about is covered in the user manual. If you didn't get one, it may be a good idea to acquire one. For example, there are several conditions where your auto-stop won't engage - temperature being one. In the 03 it's < 41 degrees BTW. Also, there's a brake condition that needs to be met (it won't turn your car off unless the brakes have enough pressure (or vacuum) to work). :-) It also won't go off unless you have enough juice in the battery to start it back up.
Not sure about the timing belt -I just had my 60K service and it didn't require it. This would also be in the user manual. My guess would be at 100K.
Couple other quick tips - go with 0W20 oil (you may have to buy from auto store - Jiffy Lube and such does not carry). Or get it changed at the dealer. Watch the tire pressure and tire selection. If you don't have Bridgestone 320 (I think) or Dunlop SP20's then they've been replaced. If they didn't change out with a low-rolling-resistance (LRR) tire or the replaced with originals, you may have some mileage issues. Not much - 2-3 MPG at most.
The batteries seem to be wearing well - several on here have over 90K miles and the batteries are fine.
Congrats on the new car!
Old Jan 15, 2007 | 12:03 AM
Thanks man!
I figured out the auto-stop problem, the econ button needs to be turned on!
Tires are some cheap generic tires - at 360 treadwear, they will be replaced soon.
I've had a lot of trouble finding 0w20 too, what brands have you guys found that meet the specs?
