HELP - My car randomly will NOT start (04 Civic Hybrid)
Old Oct 14, 2008 | 07:02 PM
read2me's Avatar
Default HELP - My car randomly will NOT start (04 Civic Hybrid)
My car will simply not start at random times. The lights on the dash and all come on fine, but the engine is completely SILENT. After turning the key on and off 7-8 times the engine will just turn over as if there was never a problem.
Then the car will turn on fine for a couple weeks and just today I went out to the store and when I got back in the car it would not start. After about 10 tries, it just started right up.
The engine does not make a sound when it won't start, no trying to turn over or cranking noise. Just silence then it suddenly starts right up.
Old Oct 15, 2008 | 07:29 PM
kenkobra's Avatar
Default Re: HELP - My car randomly will NOT start (04 Civic Hybrid)
Sounds like you have a bad ignition switch or a bad neutral switch. When this happens again try put the car in neutral and wiggle it. See if this fixes the problem. If it does have the dealer check and see if the neutral switch needs to be replaced or is out of alignment. As for the ignition switch, I had one go bad on my Honda and it was about $280.00 to fix the problem.
cody07hch
Aug 18, 2019 09:11 PM
hondarider90
Aug 1, 2013 02:09 PM
bbmotor
Jul 28, 2010 11:34 AM
bilbro
Aug 6, 2008 06:02 PM
