Glowing Hybrid Logo
Old Apr 6, 2005 | 05:13 PM
dpmitche's Avatar
Cool Glowing Hybrid Logo
Official comment: Ouch Ouch Ouch!
Ok if anyone else gets this bright idea, remember that the transformer is converting your 12 volts into 110+-, and if you touch the edges it feels like being hit by a stun gun.
I have a long way to go before this ends up on the back of my HCH, namely waterproofing, but I took this preliminary picture to get the feel of what it will eventually look like.
ouch.
Old Apr 6, 2005 | 05:19 PM
Jason's Avatar
Site Founder
Default Re: Glowing Hybrid Logo
Looks very neat! I look forward to seeing a picture of it on your car. Be sure to add it to the Share section!
Old Apr 6, 2005 | 06:50 PM
ericbecky's Avatar
Contributor ($)
Please be sure you post an picture of you actually touching it, too!
Old Apr 6, 2005 | 07:00 PM
tbaleno's Avatar
I wonder if you painted it with clear coat or something it would protect it from the weather as well as prevent a shock from touching it.
I don't know if it would work or not, its just an idea I had.
Old Apr 7, 2005 | 02:07 PM
mppkll's Avatar
This is very cool! How did you do this?!? What is the material that is glowing?!?
Old Apr 7, 2005 | 02:35 PM
jdawg70's Avatar
Using an electroluminescent sheet by chance?
A healthy application of a Krylon spray should be able to do the trick for the waterproofing.
Old Apr 7, 2005 | 03:35 PM
zhybrid's Avatar
Love it! If something like this was an option or aftermarket purchase... I'd likely buy it.
Old Apr 8, 2005 | 03:28 PM
dpmitche's Avatar
Yep, it's an electroluminescent sheet, available off eBay for $12-$22 USD. I learned the hard way that the layers in the sheet are not strongly bonded together, so they will peel apart if your not careful. I've ripped it all off and am starting over again. This time I'm going to place the EL sheet with the glowing side AWAY from the logo (so it'll eventually face the vehicle). I then plan on placing either a layer of the recommended krylon spray on top of it, or a layer of clear 2-ton epoxy... Then I'll try sanding it down so it's flat. HOPEFULLY this will only raise the badge up 1-2mm more than it was stock, and with the EL sheet facing the car then it SHOULD give a snazzy glowing effect again.
Old Apr 8, 2005 | 03:36 PM
n1ywb's Avatar
Eye am teh smartey
That's PIMP! Can you make me one?
Old Apr 8, 2005 | 03:42 PM
tbaleno's Avatar
If you cold make it solar powered or something that would be cool. It would be nice if there was a way to make it self contained and self powered.
