Coasting question
I apologize if this question has been answered already, but I didn't find anything about it in a quick search of the threads... My question is this: When I got my new Civic Thursday, I asked the salesman whether I should continue my habit of coasting to a red light in order to avoid braking. He specifically advised me to NOT do that because the braking charges the battery. Was that bad advice? (He said he had only been with Honda for about six months and was an airline mechanic before that, so I trust your answers!) Thanks in advance.
Re: Coasting question
Coasting and braking both use no gas so doing them for the same distance is equally fuel-efficient, and braking for a shorter distance than coasting is less fuel-efficient. But if you do do them the same distance anyway, braking will generate more electricity than coasting.
What CGC Said.
An interesting habit to get into with your new civic is that *before* you start that initial coast into the upcoming stop, you can sort of nudge on the brakes a little which "activates" the regeneration system. (It's not really an on/off switch, but it'll alert the car's brain that, oh, we're getting ready to stop) and it starts the battery charging dance.) Having said that, though, the one place that coasting will become *crucial* to your mileage is at-speed. Find the places where you do not need to have your foot on the pedal to make the car move forward, and find a practice of giving "love taps" to the accelerator to keep the car moving, rather than constantly pushing on the pedal. The more you coast along in that mode while driving, the more green lights you'll see on your dash. (The technique is referred to on here as "Tap and Glide") Doesn't work for diddly-squat in an Accord (different theory of how to save gas in that car) but you can really take that technique to the bank by the time you get the car good and broken in. |
Hay whats up:shade:
Your habit of coasting to a red light in order to avoid braking is the way to go. coasting allso charges the battery to. This is what i have been doing and never had my battery go less then 1/2 its charge;) . |
Typical of these sales people to know less than their customers. Once they figure a way to have the customer do the paperwork, I think most of these sales people are going to be toast.
The less acceleration the less gas. The batteries know what they're doing. Simple as that. |
For maximum fuel economy between lights, accelerate up to speed normally, then "glide" as much as reasonably possible, using the electric boost. If you are coming up to a stop, brake lightly-- just enough so that you get maximum charging, but not so much that you engage the regular brake pads, unless necessary. |
I use coasting / "Zero Fuel Gliding" as an integral part of my technique. When in town, about 300-500 yards before a red light I let off the gas to start my glide. It seems as though most drivers are less inclined to ride your rear or zoom around you as you approach a red light ... well that it is dependent upon the maturity of the other drivers. I also extend out my braking in town when the battery is at around 4 bars. I've notice when I have a fully charged battery, the IMA really helps fuel economy.
Another way to think is don't get up to a very high speed close to where you may have to slow down.
If you do you may have wasted some of that gas. When it IS time to decide to slow down (whether using the brakes or coasting) wouldn't it be smarter to be going 35 instead of 45? Also leaving a lot of space in front of you helps save gas cause you have more time to gradually slow down, and didn't waste gas to get up to speed to follow so closely. |
