check gas cap warning
Old 05-08-2006, 06:54 PM
jaykay's Avatar
Default check gas cap warning
Suddenly in the middle of a tank without any touching of the gas cap, the check gas cap warning flashed where my odometer should be. I will bring it in to the dealer. Any one seen that?
Old 05-08-2006, 07:30 PM
JJanney's Avatar
Default Re: check gas cap warning
I had it. Read your manual and do a search of these forums.
Old 05-09-2006, 08:12 AM
wstiefer's Avatar
I saw that for the first time last Monday morning, May 1st. I stopped my the dealer just to make sure everything was OK. They explained that the system only goes through a vaccuum check about every 3 days or so. I opened the gas cap and closed it again making sure it clicked at least 3 times. By Friday the message had disappeared once the system did a vaccuum check and everything checked OK.
Old 05-09-2006, 08:45 AM
moosh's Avatar
Owner
It happened to me after I rinsed off my old lawn mower. The mower filled my garage with a wet grass/gasoline smell. The "check cap" indicator came on a day later. Coincidence? I read on here that a gas fumes sensor will trigger the indicator.
Old 05-18-2006, 04:42 PM
TerrierMom's Avatar
This happened to me the other day. I've re-tightened the gas cap a couple of times. I filled the tank at a Valero gas station near my brother's place in a rural area of the state Sunday. The gas pumps were the older model without the Vapor Recovery Hose. Also my brother's driveway is in severe need of re-graveling,full of deep ruts that scraped the botton of poor Timothy The Tri-Toned Honda Civic Hybrid in a most alarming way.Was about to call my dealer about it, but now am not worried and will wait to see if it resets itself.
Old 05-18-2006, 06:09 PM
jaykay's Avatar
I went out of town for 3 days and when I got back the warning didnt go on when i started the car. It took about 5 or 6 days to reset
Acee
09-21-2010 09:47 PM
FamilyMan
06-09-2008 07:57 PM
tanstaafl14
11-14-2007 10:17 AM
JJanney
06-16-2006 09:25 AM
NASAgineer
04-05-2006 07:57 PM
