Check Engine Light
Check Engine Light
Hi I just bought a 2003 Civic last week, so far I love it. Only problem is the check engine light came on a few days after I got it home. Took it to AutoZone and had them pull the codes and it came back with a catalytic converter inefficiency code. Anyone else had this problem, it is a Honda certified used car so atleast I have a warranty.
Very obvious comment.
Since it is under warranty I'm going to make the most obvious suggestion that you take it to a dealer and have them go through it. Knowing what the computer code says is important, however sometimes code descriptions are misleading. Sometimes a dealer gets a code, but it can mean about 5 different things. Sometimes not.
I'm glad you are under warranty.
So, you are driving a Civic Hybrid? Looking at the profile information that shows up in the upper right, I wasn't sure. I guess I'm being stupid this afternoon.
Anyway, I know that the Prius has a rather complex catalytic converter system. I believe they refer to it as 3 stage. Don't ask me what that means other than I probably has 3 different stages in it. But the only thing I have ever heard about Prius problems have been an occasional O2 sensor that got fouled and had to be replaced. And that is pretty rare.
A quick google and I found this at BBA-reman.com
"A Three-Way converter is a triple purpose converter. It reduces nitrous oxides into nitrogen and oxygen. And, like the two-way converter, it oxidizes unburned harmful hydrocarbons and carbon monoxide into water and carbon dioxide."
I'm going to get it to the dealer soon, and I just thought typing Civic Hybrid in the Hybrids owned was kind of redundant. I was think it might have been sitting on the dealers lot for awhile and a fresh tank of gas would make it go away. It hasn't.
stoshiro
01-12-2021 04:11 PM
cak615
10-28-2013 09:11 PM
funnd
08-01-2012 01:23 PM
SadCarTime
07-09-2012 09:05 AM
