2012 Honda Civic launches with new HF model; hybrid goes lithium
![Post](https://electricvehicleforums.com/forums/images/icons/icon1.gif)
http://green.autoblog.com/2011/02/17...-goes-lithium/
Of particular note:
Of particular note:
* EPA-estimated Civic HF highway fuel economy: 41 mpg
* EPA-estimated Civic Sedan and Civic Coupe highway fuel economy: 39 mpg
* EPA-estimated Civic Hybrid city/highway combined fuel economy: 45 mpg
I dont know how deep Honda cycles/ discharges their battery pack ( don't own a Honda HDS tool), I'd wager it's conservative. IF I obtain a HDS, I would LOVE to set the discharge cycles from full to 10% SOC ( NiMH ) and increase the amperage discharge rate somewhat....I'd bet it COULD achieve 100 MPG. I am basing this off of rumors that MOST MFG's only cycle batteries 20-30% SOC.
From the 1st PDF at http://priuschat.com/forums/gen-ii-p...provement.html (describing the 5 "stages" of Prius operation)
One should still seek to minimize regenerative braking because of the energy losses upon conversion to and from the HV battery.
I refer to this as the Hybrid Paradox: You bought the car for the economy of the battery, but must minimize use of the battery for optimal ecomomy.
Prius hypermilers aim to minimize amount they add to or remove from the HV pack.
As for SoC range, I can confirm your statement on the 2nd gen Prius. http://privatenrg.com/#Full_SOC has a mapping of the display to SoC values. I also monitor the actual % SoC via ScanGauge. The Prius starts doing funny things around ~75% SoC if you're going down a hill to prevent overcharging (it essentially puts itself in B mode, spins up the ICE and runs it at high RPMs, etc.) It rarely goes below 50% SoC (or 1-2 purple bars) unless you're idling for a long time or creeping a long for a long time, esp. w/AC running.
I don't think I've ever seen SoC % get above 81 or 82% and the only way to get there is by going down a long downhill grade (or maybe force charging by holding down both pedals, which I don't do).
Jon1958
04-04-2013 04:10 AM
Curated Content Editor
11-04-2012 06:00 AM
Jason
Hybrid & Related News
03-29-2005 04:22 PM
