2008 honda civic hybrid antenna
We are considering buying a Thule roof box, and wondering about that odd black antenna that sticks out at an angle from the back of the roof -- will it be in the way?!
Many thanks.
Glad to have discovered this forum.
Frances & David
Many thanks.
Frances & David
The antenna unscrews and can be left off - It is only used for AM radio - since I never turn on Antique Static AM radio, I have no antenna sticking out - just use the mp3 player 100% of the time, FM works fine without it.
Thanks very much for the reply, larryr.
That makes it a non issue.
Now, we'll just figure out how to unscrew it, but knowing that it is supposed to should make it a lot easier.
Many thanks,
Frances & David
Many thanks,
Frances & David
Off topic, but can't resist:
We had a 91 accord with power antenna in the trunk. It was wired to run up everytime the radio was turned on, even if it was just to play a tape (remember those?), and run back down every time the radio was shut off.
It took about 18 months for the first failure and repair. The dealership cautioned me to frequently clean and lube the telescoping aerial, which I did. It continued to fail. It finally clapped out completely. All in all we spent $100's on that dang thing.
You see a lot of that gen of accords driving around with aerials stuck half way up, or replaced with aftermarket stubbies.
Just to clarify... any year models with GPS/NAV or '09 models with XM radio do not use that antenna except for AM radio?
I have Yakima roof racks with a Yakima 11 cubic ft. locking trunk. The box is about 7' long and 18" wide. It is call space booster and is very easy to put onto the racks. The box has 4 clamps you fasten from inside. I also pack my Kayak on the other side of the antenna. Oh , I should mention that the racks are lockable as well. And I had to install a fairing for noise. Racks a very easy to remove and install and very good quality. Hal
Most other civic model have the am/fm antenna in the pattern on the rear window that is not the rear window heater.
