2007 Civic Hybrid Head JOB, Burn Exhaust Valve
5 Attachment(s)
hello. let me introduce my self.
my name is Raul. I'm from San Diego, California I purchase a Civic Hybrid and I'm not happy with it. its been 132k miles and still get about 36-38 MPG. and i drive like Gram-pa. Just recently. i change the Exhaust valve. it had a Hole on the #2 Cylinder Valves. I just got my Software Updated Today. and i have not fully tested it.. I will keep you guys update any improvement on my Car. Also my Grammer and spelling suck. please fell free to see "What?? By the way. What kind of battery can i install on my Hyrid? will the 2009 or new Civic batter pack work for my car? or is there Modfication i could do? |
Re: 2007 Civic Hybrid Head JOB, Burn Exhaust Valve
Thanks for the excellent pictures and letting us know about this problem. First valve issue that I am aware of? Hope your FE improves. I am sure it will. Did you purchase from a Dealer? Looks like something dropped into the top end if that is possible? H
Indeed it does and looks like that valve was running like that for quite some time according to the erosion around the hole. I'd say there was a small crack in the valve and it eventually became that ugly hole after a few thousand miles. With over 2k moving parts, something's gotta give eventually. Sorry yours was only at 132k miles though =(
MPG dint improve... i still get 34-36 MPG..
I adjusted the Valve Factory Spec. but i still hear Valve Clicking. not loud like it used to. but still clicking.. is this normal? |
Jamchel, i also notice when i try to adjust by valve, that when i follow the Valve adjustment instruction it seems like the valve still open.
Example. I put the camshaft to #3 mark on TOP of the cam case, i notice that Rocker ARM still move very slightly. I know that both Exhaust/Intake Valve has to be Fully close with the Rocker arm Fully LIFTED. me following the instruction will not allow me to put the Rocker arm fully LIFTED/ What i did is. I just keep turning the Engine Until i see both Rocker ARM Lifted and not moving when i slightly move camshaft. and when i see the Valve Spring has no Compression. and then I do the Adjustment on the valve Will this work? it seems like it does. Please Education me |
