2003 HCH Hybrid Battery Rebuild
Old Jan 28, 2013 | 06:31 AM
Base430's Avatar
Default 2003 HCH Hybrid Battery Rebuild
Hello Everyone,
I am new to this forum. I hope I can find my answers here. I am sure these questions have been asked. But I have looked and there are no specifics on these issues.
So, I have started the Hybrid Battery Rebuild. I removed the battery yesterday. Which I believe was blown out of proportion by a lot of posters. One of the easiest things that I have done. I am fully aware of the fact of the high voltage. As long as you are careful to flip the switch. You should be fine. I broke the battery down to its individual sticks. And I have started charging the Cells. Once I charge then I will be Cycling them.
I have a few questions:
1. What was the charge rate you were using? I started using 3.3A. But I heard one of the batteries relieve pressure. So I backed down to 2.3A. And that seemed to work. I am using a Triton EQ charger for this.
2. I know there will be bad cells. Does anyone know where I could get individual sticks? If not, does anyone know where I could get a cheap pack. I will go ahead and test all those individually also.
Any advice, information or warnings would be helpful. Thank you again.
Old Feb 13, 2013 | 01:35 PM
drozzin's Avatar
Default Re: 2003 HCH Hybrid Battery Rebuild
I think 3.3A ad even 2.3A is too high of a current for this battery.
The normal charge rate should be C/10 which means about 0.65A.
With sophisticated charger the charge rate may be up to 1C or 6.5A for individual cell.
Since you are charging a group of cells connected in series I would go above 0.65A because the high charge current may overheat individual weak cells.
Old Mar 29, 2013 | 07:38 AM
raydon's Avatar
Originally Posted by Base430
Hello Everyone,
Old Apr 15, 2013 | 10:17 PM
skiracer8148's Avatar
Interesting my HCH now has 230K on it so im pretty sure the battery is shot, I didn't know you could rebuild them.
Old Apr 18, 2013 | 09:29 AM
tbaleno's Avatar
Mine is still going okay (see a few ima lights occasionally but they go away.) I'm waiting to see if re-volt gets lithium pack developed for the HCH I this year. I'm too much of a coward to rebuild my own.
mikean16l
Sep 30, 2014 04:39 AM
stoatly
Sep 3, 2014 04:19 PM
ArthurKnowles
Feb 27, 2013 09:12 AM
SadCarTime
Jul 9, 2012 08:05 AM
simply2crazy
Dec 19, 2011 06:23 PM
