IMA/Battery Stick Troubleshooting
2003 HCH CVT 180K
The IMA is bad. When I reset the error, it comes right back on. P1600 and another ... research in the threads states bad IMA.
I found an entire unit on CRAIGSLIST for $300. The lister states it causes errors - but suggests to take sticks from it and use them to repair yours...
So, these sticks, can you troubleshoot them? Is there a known procedure, or a test unit?
Seems logical if I find good sticks to install them and whalla...or is it not that simple.
Any info would be greatly appreciated. I need to fix this thing.
Thanks,
tja
Thanks,
tja
Maybe a moderator could get this post moved over to the Civic Hybrid forums. . .
I don't know if I'd be man enough to risk the time or money to try this--seems like a real long shot. Perhaps others have done this.
Good luck to you!
Good luck to you!
nstarz
May 19, 2015 10:42 AM
green_degree
Nov 19, 2008 04:40 PM
