Weired Smell in 2007 HCH
Old Jun 25, 2010 | 04:00 AM
m.isbeer's Avatar
Default Weired Smell in 2007 HCH
Hi all,
I have a 2007 HCH that i just bought, but every now and then while i am driving it, this weired smell, comes out i donno from where, some say maybe from the catalyzer, the smell is like still water that was left for days...
Does anybody have an answer for such a problem
Thanks all.
Old Jun 25, 2010 | 12:36 PM
Mendel Leisk's Avatar
Default Re: Weired Smell in 2007 HCH
Check the cabin filter? It's behind the glove box: you just need to coax the g.b. to swing all the way down, by pushing in it's side walls, to get at the filter.
Old Jun 25, 2010 | 03:08 PM
Dream'R's Avatar
Following on from Mendel's suggestion, you may want to see if there is any moisture in the "air box" where the cabin filter is located. When the air conditioner operates, there is condensation formed from the humidity in the air entering the car. There is a drain which leads to the outside under the car but this can become plugged by dirt, mold, etc. (This is why you will sometimes see a small puddle left under the car when you have been using the air conditioning).
Good luck!
Roger
Old Jun 28, 2010 | 01:30 AM
m.isbeer's Avatar
the smell only appears when i hit the gaz and the RPM goes above 2.5. is that releveant to the problems you guys described??
Thank you soo much for your help.
Old Jun 28, 2010 | 09:30 AM
Dream'R's Avatar
This sounds like it's related to your exhaust system then. The catalytic converter will sometimes produce more odor in the exhaust. The stagnant water smell you describe may also be from condensation in the exhaust which evaporates as the system heats up.
(I notice this when I start my motorcycle after it's been sitting for a while).
I think it would be worth having the entire exhaust system checked for leaks or damage. You should not be able to smell the exhaust when inside the car.
Cheers,
Roger
prius_owner
May 6, 2017 05:27 PM
FAQOPEC
Apr 5, 2006 06:50 AM
tonto
Oct 14, 2005 12:15 PM
hawkGT647
Sep 29, 2005 08:34 PM
impala
Jun 16, 2005 11:13 AM
