Tire Question
Are the Dunlop SP31 A/S "directional" tires?
(i.e. - should they only be rotated front/back - not left/right)
What is your recommendation for a replacement set? I want a 50/50 split between LRR and traction (i.e. - I don't want to sacrifice one to get the best of the other).
Thanks,
FamilyMan
Thanks,
FamilyMan
Thanks,
FamilyMan
Thanks,
FamilyMan
I believe that any tire that qualifies as LRR provides inherently poor traction and just "so-so" handling. I am pretty happy with the Dunlops even when having them inflated at 48-50psi, but then again, that is my interpretation of good.
Michelin and GoodYear do have "LRR" tire products that may be worth investigating, though.
Cheers;
MSantos
I bought these...
http://www.tirerack.com/tires/tires....nSpeedRating=S
They do great in the dry and wet. I have another set for snow.
How is your mileage with the Sumitomo HTR200 185/70HR14? How long have you had them?
I notice tirerack lists that as the right tire for the 2003 HCHI, and they have a comparable Sumitomo HTR200 for the 2006 HCHII which I'm thinking about. The reviews on tirerack.com say it's decent in puddles, while I'm kind of nervous in the rain on the OEM dunlops I have, although I like their dry performance.
I generally find that the liking of a tire depends much on your taste. I've read many tire tests, but they don't always match with my experience.
For instance, my previous car (a Honda Accord) came with Bridgestone tires that I liked OK, but thought were a little noisy. From a test, the Michelin Energy came out very good (also in noise performance). Then once I got a loaner Accord with those exact Michelin tires, and I perfectly disliked them for their steering feel and they were much noisier than the Bridgestones too.
Therefor, I usually stick to what I have, when I half like it. You know what you have, not what you will get until you get it, and then you are stuck with them for the next x-thousand miles.
My HCHII came with Dunlop SP Sport 300's that seem OK to me.
MPLSMN
02-16-2010 04:59 PM
