Time for brake fluid change/flush... DIY?
my 2007 HCH-II is in need of a brake fluid change (per recommended interval) and from what I've researched it may be a little trickier to do than with a non-hybrid vehicle... I've done brake fluid changes before with no problems, but with the HCH2 I'm a little worried due to the different brake system. On a normal car you can easily feel the pedal get stiff as you build pressure before opening the bleeder valve, but I don't think it's the same on the HCH2 - at least from what I've read... Anyone have a DIY on how to do this? If I take to the dealer how much should it cost?
Yes, the DIY is to take it to a dealer and let them do it. I am the biggest advocate of DIY brake flush, but the way the ABS works on this car and the location of the fluid reservoir makes it oh so easy to get so much air in the system, you can never get it out. Plus to get to the reservoir you have to remove the MAF then turn on the car which makes it throw a code, which you need to reset, etc. etc. Just pay them to do it. It can cost between $50 and $150 depending on your localities GF (gouge factor)
07civichybrid
Sep 15, 2018 06:17 PM
Orient Express
Feb 3, 2015 06:05 PM
dwichman
Aug 19, 2009 06:58 AM
atikovi
Dec 22, 2006 11:40 AM
Hal
