Spark Plug Details for 2006 HCH II
Old Mar 15, 2016 | 01:56 PM
ckendall37's Avatar
Default Spark Plug Details for 2006 HCH II
I've seen multiple threads about spark plug requirements for my 2006 HCH II, but some provide conflicting guidance. Could someone please tell me which Denso plug part number I should use on my 2006, along with gap and torque specs?
Thanks!
Old Mar 15, 2016 | 03:40 PM
Default Re: Spark Plug Details for 2006 HCH II
Really? Where is the conflicting guidance?
https://www.greenhybrid.com/forums/f...tml#post256978
They come pre-gapped. No adjustment is needed.
use anti-sieze, 13 ft-lb torque.
Old Mar 15, 2016 | 06:49 PM
ckendall37's Avatar
I've seen different part numbers listed from various sources. Are these correct parts:
12290-RMX-004 008 SPARK PLUG (SK20HPR-L11) (DENSO)
12290-RMX-014 008 SPARK PLUG (SK20HPR-L11) (DENSO)
12290-RMX-003 008 SPARK PLUG (ILFR6J-11K) (NGK)
12290-RMX-013 008 SPARK PLUG (ILFR6J-11K) (NGK)
I'm also not clear on what the difference is between each pair listed for each manufacturer. They have the same model number, but the part number varies slightly.
Old Mar 15, 2016 | 06:57 PM
As you notice, the manufacturer number is the same. The difference in OEM P/N isn't relevant. Likely a stocking issue or former supersedure.
Dealers will charge you $25/plug.
Just get the NGK/DENSO part number from a parts store for about $14.
Old Mar 15, 2016 | 07:08 PM
ckendall37's Avatar
Thanks for the advice!
Old Mar 19, 2016 | 10:53 AM
Colematthew82's Avatar
https://www.greenhybrid.com/forums/f...tml#post255504
iafb83
Dec 19, 2009 07:23 AM
pagemap
Jul 9, 2008 11:40 AM
mdkeeper
Feb 18, 2008 08:23 AM
end
Apr 21, 2007 08:53 PM
lkewin
Oct 20, 2005 07:58 AM
