Replace 12v battery myself?
Old Apr 11, 2012 | 07:57 AM
xoham's Avatar
Default Replace 12v battery myself?
With advice from this board, I replace my own air filters and saved a bundle easily. Honda wants $138 to replace the battery and they suspected I would rather do this myself. Should I? I've been told that a shop will maintain power to the card while they do the job which is better for the car, but I've also heard you don't need any special tools and its easy.
Also, please recommend a battery.
Old Apr 12, 2012 | 01:57 PM
aminus21's Avatar
Default Re: Replace 12v battery myself?
Check out this thread :https://www.greenhybrid.com/discuss/...etailed-27545/
Many users have had good results with the Interstate battery.
Old Apr 14, 2012 | 07:11 PM
hertfordnc's Avatar
Depending on how much of a DIY cheapskate you are.....
I replaced my OEM battery with a large lawn tractor battery for $40. I've had it over a year, through a mild NC winter.
I really doubt there is any consequence to disconnecting the 12v power completely, as long as you know your radio code. Also, your current MPG numbers will go away.
If you really want to keep it hot you could make up a cigarette pigtail and connect it to a 12v source- and leave the key on.
Or you could use jumper cables from another car.
grnhybrid
Dec 10, 2011 12:27 PM
jonathannevins
Nov 14, 2010 07:45 PM
1SMUGLEX
Introductions
Apr 19, 2009 06:35 PM
galaxee
Introductions
May 4, 2005 09:12 PM
