Need to re-enter Navi Code
Battery had died and now I need to re-enter the anti-theft activation code. The manual is less than obvious on how to enter the number. My understanding is to push the preset buttons to match the four digit code. However, one of my code digits exceeds the "1-6" listed on the presets. So how do I enter an "8"?
I would ask the Service department but got re-routed and then hung up on... So looking for ez-way out.
Jesse
Jesse
I thought I might have that problem someday when I was first picking up my car. I, too, didn't see anything in the manual.
If you open your glove compartment...there is a sticker on the left side--closest to the Navi. The code is on this sticker.
Good Luck!!!
Good Luck!!!
Brad,
Are you talking about a long single-line white sticker with a long code on it?
It looks like a serial number - GFB#########A, or so.
If so, I presume the last four DIGITS are the code.
And if so, none of mine are greater than 6.
Steve,
You got me on that one. I am not sure because I haven't ever had to re-enter it. I was just passing on what I was told by the dealer during the post sale counseling. I am positive that they said that the sticker has the code on it.
Let us all know what happens. Just in case any of us need to re-enter the code someday.
Wish I could have been more help.
Brad
Brad
Thanks, Brad.
I'm just gathering information for the future as well.
I don't need it right now. Jesse does.
BTW, did you notice how the NAVI clock "fell back" automatically this Sunday?
You can look in your Honda service log manual for this 4-digit code. The 1st 2-digits activates the radio, the 2nd 2-digits will activate the DVD. This information should have been hand-written in by the dealer during the inspection process prior to sale of the car. Apparently this manual is also used as an inspection check-off list for new vechiles.
Hope this helps.
Hope this helps.
Oddly enough, when I started up the car yesterday, it brought up a numbered key pad on the screen to enter in the code. I entered it, and everything works fine.
This screen did not come up before on the 5 previous times that I started the car since charging. Very strange.
OK, I found my code!
When buying the car, the dealer gave me a manilla folder with some stuff in it (contract, window sticker, etc.). Included was a credit-card sized thin plastic card, called the Navi Ant-Theft Identification Card. It is white with a dark blue Honda logo in the upper right corner, with black lettering.
On the front of the card is the 4-digit Code Number (mine has digits above #6, also). Below the Code Number is the Serial Number. This serial number is the number that is also found in the glove box.
On the back of the card are these instructions:
When the unit is switched on after being disconnected from the battery, "ENTER CODE" may be displayed on the navi screen.
Enter the 4-digit navigation code using the touch screen or the joystick.
GPS initialization may be required.
Even if "ENTER CODE" is still displayed after you enter the codenumber, input the code number again.
My guess is that the GPS had not initialized, therefore you did not get the "ENTER CODE" screen right away (until it finally did get initialized).
super80
Sep 27, 2006 07:43 PM
