Intermittent Wipers Change
Old Nov 1, 2006 | 01:05 AM
Donald's Avatar
MEAN TO BE GREEN ACTIVIST
Unhappy Intermittent Wipers Change
I'm having a unusual problem with my intermittent wipers. At the slower speeds sometimes it sweeps once (should do this) - BUT sometimes it will sweep 2, 3, 4, 5, or 6 Xs in a row. It also will occassionally stop in the wide open (goal post) position when I turn the car off. I've also noticed that sometimes the wipers stop with one on top of the other, and both stick up a few inches on the windshield (in between sweeps with wipers still on). Any one else experienced any of these problems?
Thanks,
Old Nov 1, 2006 | 09:20 AM
Anahymbrid's Avatar
Default Re: Intermittent Wipers Change
I haven't had much opportunity to use the wipers, but from the few times I have used them, I don't recall them operating this way. Sounds to me like there is a problem.
Old Nov 1, 2006 | 08:04 PM
exbauer's Avatar
I haven't experienced this in my car. Sounds like you should have the dealer take a look at it since it is under warranty.
Old Nov 3, 2006 | 06:44 PM
Flash's Avatar
I haven't experienced the wipers sticking in the GOAL!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! position but there is a feature when the wipers are on the Intermittent setting and set to either the fastest speed or the next-fastest speed. This feature is that when you are driving the wipers clear at maximum Intermittent speed until you slow down to a stop or an Auto-Stop and then the wipers stop or wipe every 5 seconds or so. THEN, once you take your foot off the brake the wipers clear the windshield once until you get up to a little speed and then they clear at max Intermittent speed again. I like this feature. Good luck on your wipers though and let us know what the fix is.
infael
Jul 22, 2007 03:31 PM
tnsig
Jan 15, 2007 09:16 AM
joeman2006
Nov 6, 2006 12:23 PM
Kazdor
Mar 1, 2006 06:58 PM
nbalthaser
Feb 22, 2006 10:08 AM
