HCH2 trunk lid liner
Has anyone installed a trunk lid liner in thier 2006 or newer. Is it worth doing. I believe it will look cleaner, but does it help with road noise? H
![Sad](https://electricvehicleforums.com/forums/images/smilies/emotikons/sad.gif)
It was included with the 2007 and newer models, but not the 2006 Bob. I've ordered a liner for my trunk lid. If anything it will look better when the truck is open. I am hoping it will cut down on the road noise as well. H
Hi Harold.
My 2006 did not have one either. I did install it though soon after I got the 2007. All it takes is 2 properly sized holes to be drilled in each trunk hinge arm so that the left and right garnish can attach securely.
Cheers;
MSantos
Cheers;
MSantos
Hi msantos
Did you notice Any change in road noise? I installed mine today and it seems to have helped quiet things a bit . Sure cleaned up the trunk.
Cheers;
H
![Teeth](https://electricvehicleforums.com/forums/images/smilies/emotikons/teeth.gif)
Cheers;
H
Hi Harold;
I admit I did not notice any significant reduction in noise - perhaps I was not hearing hard enough. But I agree with the "clean up" aspect of it as it helps make it "tidier" looking.![Wink](https://electricvehicleforums.com/forums/images/smilies/emotikons/wink.gif)
Cheers;
MSantos
Cheers;
MSantos
Andy. Just go to www.collegehill.com and view it, Its about $72.00 dollars US. H
