HCH2 and extreme heat
Just got back from my weekend in Vegas with family.
Okay, I've owned my HCH2 for over 8 months now and I live in Los Angeles,
where the temps usually hover around 80 degrees.
I finally experienced my first "forced regen" in Las Vegas. The temperature was around 120 degrees and we had to have the AC on. Stuck on Las Vegas Blvd. and stopped at a light. The battery dropped to 1 bar and the car started revving up the charge bars dropped to about 3. The car had absolutely no power at all.
The day we arrived in Vegas it was also 120 deg. While on the way to pick up my brother at the airport I noticed that the vehicle does not respond like it does in Los Angeles.
First, the car does not auto-stop in 120 deg temps, no matter how low of a setting I use for the AC fan (this trick works in LA, set it at a lower setting before coming to a stop).
Second, the car would not regenerate battery power while braking? What was going on? Does extreme heat cause the HCH2 to respond strangely?
Anyone in Phoenix have a response?
So, has anybody done studies on correlation of FEH to cars that are consistently parked in parking garages during the day? That would be an interesting comparison to see if it could be feasible.
i've read on the ford website is that you can improve the performance of the batteries if one kept their FEH in the garages rather than roasting in the warm sun. Since when one turns on their car in the hot, the car has to take time to cool down the batteries before they can be used, but in the cool garage the batteries can be used instantly without delay!
I had posted on this before. Here in Houston, simply parking on a lot and then driving in the day shows autostop etc will not work in conditons of extreme heat UNTIL the battery pack cools down. Parking in a garage does make a difference as you will have all working much sooner again as normal.
